  4. Car Updates / Progress
  5. My project
My project
70 Posts 13 Posters 21.1k Views
  • DaveHD
    DaveHD
    Looks good, what turbo is that?
    • legacy-user-3898L
      legacy-user-3898L
      legacy-user-3898
      It's a gt-45 ( 70mm ) if i remember. It was free i'm planning on upgrading after it get this set-up done. I started looking at an S400 75mm with a T-4 flange. But i'm open to suggestion's
      • DaveHD
        DaveHD
        With a relatively big cube motor like that, I'd go with a T6. It leaves you a lot more options in the future if you decide to upgrade.
        • zbrownZ
          zbrownZ
          yeah if you have the room build it around a t6 footprint
          looks good!
          • legacy-user-3898L
            legacy-user-3898L
            legacy-user-3898
            I really don't know if I will have the room for a T6 unless i cut into the fender well but then i might not have room around the hood. It's kinda tight around the turbo right now plus i will not have room for the down pipe. We were able to get 3.5 inch to fit right and i really don't want to cut into the frame that much. I even think 4 inch would be tough to do.
            • legacy-user-3898L
              legacy-user-3898L
              legacy-user-3898
              well not much progress as of late. just a lot of ordering of parts. but i can say christmas is going to come early this year as everything i ordered should be here by next tuesday. then next week while i'm on vacation i will work on the fuel system and possibly pull the motor out and swap out the oil pan and weld in the drain for the turbo. i also might start some of the wiring
              • legacy-user-3898L
                legacy-user-3898L
                legacy-user-3898
                Well christmas came early for me (transmission, most of my fuel system part's, starter, and misc part's i ordered). plus my buddy got his converter back and his engine for his race car. so it has been a good week for both of us 🙂
                • legacy-user-3898L
                  legacy-user-3898L
                  legacy-user-3898
                  Fuel system is almost done just have the cross over left to do. Will get that done tomorrow and then pull the motor out and swap out oil pan's and work on the oil drain for the turbo. Than after my torque converter show's up put it all back together and figure out radiator hose's and heater hose's
                  • legacy-user-3898L
                    legacy-user-3898L
                    legacy-user-3898
                    Ok here is an update with some picture's. Transmisson is a th-350 with a b&m stall
                    • legacy-user-3898L
                      legacy-user-3898L
                      legacy-user-3898
                      well it's been a while since an update. computer wiring done under the hood and radiator ordered and modifed
                      • legacy-user-3898L
                        legacy-user-3898L
                        legacy-user-3898
                        Well it's almost done. just waiting on b.o.v. got it running last week.
                        [legacy attachment 6929]
                        • legacy-user-3898L
                          legacy-user-3898L
                          legacy-user-3898
                          Got my b.o.v. today. But i was able to drive it before i got home and saw that it showed up. Car run's really good considering it's not tuned at all. I also have traction issue's as soon as it start's to boost the tire's break loose.
                          • legacy-user-3898L
                            legacy-user-3898L
                            legacy-user-3898
                            I have been out driving it. Now to finish the exhaust and install the part of the cage
                            [legacy attachment 6934]
                            [legacy attachment 6935]
                            • kylushK
                              kylushK
                              kylush
                              looks sweet!
                              1998 Z28 Camaro
                              • RexwagonR
                                RexwagonR
                                sounds like a fun ride. how much power you think your making?
                                is your name doug?
                                • legacy-user-3898L
                                  legacy-user-3898L
                                  legacy-user-3898
                                  I really have no idea on how much power it is making yet. Only seeing about 5-6 psi right now. Yes my name is Doug
                                  • seanzi88S
                                    seanzi88S
                                    seanzi88
                                    Awesome job man!
                                    • legacy-user-3898L
                                      legacy-user-3898L
                                      legacy-user-3898
                                      Almost done with the exhaust. 3.5in all the way back.
                                      • legacy-user-3898L
                                        legacy-user-3898L
                                        legacy-user-3898
                                        Well i guess i should give you all an update. Started tuning the car under boost and damaged the rear-end ( in the words of my buddy "it was whining like an un-paid hooker" ) So i ordered a ford 9 from moser and got an upgraded drive shaft.
                                        • zbrownZ
                                          zbrownZ
                                          that rearend will be nice! what gears did you go with
                                          lets see some more pics
