  4. Car Updates / Progress
  5. The ugly silver camaro
24 Posts 6 Posters 9.7k Views
    As some have you have gazed upon my half finished cars exterior, you know I have a silver LSx camaro. Might as well make a build thread
    It was quite totaled
    So i was up for a challenge, I started to fix it. Never having done this before, whats the worst that could happen
    First time painting, I screwed up the front fenders, which will be fixed sometime but for now it looks like shit.
    My perfectly fitting hood, LOL, will be replaced which is why you have seen it unpainted for a year
    The factory suspension leaves a little to be desired, is it a 4wd?
    • 63vette6 Offline
      63vette6 Offline
      63vette
      I hope you destroy that hood and dont try to sell it to some unsuspecting idiot. That hood is a huge pile of shit, glad you are finally getting rid of it.
        SPRINGS!
        Up to this point, it had some boltons, headers and exhaust, lid, 4.10 gears and a PTC 4500 stall converter.
        [video]http://youtu.be/iQfjyMpjBGw[/video]
        It was a blast to drive but I had once again gathered a pile of parts. So....
        Ported heads, milled to death. 238/246 cam, 13:1 compression, and E85. Shortly after I Also switched to a 3800 stall PTC converter, as with the new power the old 4500 turned into a 5500
        Little idle vid
        [video]http://youtu.be/kgPimwzuuaI[/video]
        Like this the car ran a 13.000@114 on the street tires at a street legal day. I literally was spinning clear through most of 2nd gear.
        SO, i bought some drag radials, and new rims
        With that being the one and only change, the car ran 11.4@120 and i wasnt even pushing it. Still using the LS1 intake which is the most restrictive model there is, and a less than optimal exhaust setup. There is more to be had
          Though I could have done so much more with that setup, my stupidity and good deals got the best of me
          Light K-member, 35# of weight savings and so much easier to work on
          LS1 back on the floor once again!
          These showed up out of nowhere?
          Then this fell out of the sky
          378" of forged LS3 bottom end. Running the same heads and cam as that is what I spec'd the cam for when I bought it. This is
          Mahle 4.075 forged pistons
          Scat 6.125" h-beam rods
          stock crank
          Good Ls2 style timing set
          the 243 heads that I did some more porting on
          Cometic 4.085x.040 head gaskets
          EPS 238/246 .608" 111+3 cam
          BTR dual springs, ti retainers
          stock rockers with Comp trunion bearing upgrade
          It works out to be 14.15:1 compression, and around 10.55:1 dynamic compression. This will be backed up with a FLT trans stage 5 4l60e with all the good parts, and around a 5000 stall converter
            Still on a 10 bolt?
              yes, that should get replaced sometime next year
                What is going in?
                  either a 12 bolt or dana 60
                  • D S ohMD Offline
                    D S ohMD Offline
                    D S ohM
                    Looks good Gary! Let me know when you need a drive shaft. I opened up a new shop right by Tintmasters.
                    I wanna go fast!
                      Super victor and fuel rails
                        You should make that thing turn corners instead...
                          only corners around here are offramps! Not much point in it
                            Come down to the cities and go to an event at DCTC.
                              No thanks, not even interested
                                80#/ 850cc injectors
                                Should be more than enough corn
                                • legacy-user-351L Offline
                                  legacy-user-351
                                  Well sheesh, we run the same size injectors then... 😄 (okay, so I only run 4 of them...)
                                  Looking great Gary, I hope I get to see it run next summer!
                                  Turkeylord
                                  '05 Yamaha Zuma - Stock
                                    I'll go if you go....
                                      You will never sack up and come down here...
                                        So this is the harness, it sucked big time to do, but it looks so much better. all done up in heat sleeving an no more corrugated plastic loom, god i hate that shit. I need to pick up a couple parts since I broke 2 of the small metal injector terminals. But its basically done and as good as I could get it. Think I have about $45 in heat shrink in this and have enough left to do a good amount of the engine bay harness as well. Wasnt planning on it but in the back of my mind I could hear Jim telling me "that wiring is fucking garbage" and I didnt want to go through that hours long teasing session
                                          Got the longblock together this weekend. Need to get a couple small parts and have the intake milled this week.
