  4. Car Updates / Progress
  5. The ugly silver camaro
24 Posts 6 Posters 9.9k Views
  • GrrG
    GrrG
    SPRINGS!
    Up to this point, it had some boltons, headers and exhaust, lid, 4.10 gears and a PTC 4500 stall converter.
    [video]http://youtu.be/iQfjyMpjBGw[/video]
    It was a blast to drive but I had once again gathered a pile of parts. So....
    Ported heads, milled to death. 238/246 cam, 13:1 compression, and E85. Shortly after I Also switched to a 3800 stall PTC converter, as with the new power the old 4500 turned into a 5500
    Little idle vid
    [video]http://youtu.be/kgPimwzuuaI[/video]
    Like this the car ran a 13.000@114 on the street tires at a street legal day. I literally was spinning clear through most of 2nd gear.
    SO, i bought some drag radials, and new rims
    With that being the one and only change, the car ran 11.4@120 and i wasnt even pushing it. Still using the LS1 intake which is the most restrictive model there is, and a less than optimal exhaust setup. There is more to be had
    • GrrG
      GrrG
      Though I could have done so much more with that setup, my stupidity and good deals got the best of me
      Light K-member, 35# of weight savings and so much easier to work on
      LS1 back on the floor once again!
      These showed up out of nowhere?
      Then this fell out of the sky
      378" of forged LS3 bottom end. Running the same heads and cam as that is what I spec'd the cam for when I bought it. This is
      Mahle 4.075 forged pistons
      Scat 6.125" h-beam rods
      stock crank
      Good Ls2 style timing set
      the 243 heads that I did some more porting on
      Cometic 4.085x.040 head gaskets
      EPS 238/246 .608" 111+3 cam
      BTR dual springs, ti retainers
      stock rockers with Comp trunion bearing upgrade
      It works out to be 14.15:1 compression, and around 10.55:1 dynamic compression. This will be backed up with a FLT trans stage 5 4l60e with all the good parts, and around a 5000 stall converter
      • MisterCMKM
        MisterCMKM
        Still on a 10 bolt?
        thrash;315544 wrote:
        Ford is back :)
        • GrrG
          GrrG
          yes, that should get replaced sometime next year
          • MisterCMKM
            MisterCMKM
            What is going in?
            Ford is back :)
            • GrrG
              GrrG
              either a 12 bolt or dana 60
              • D S ohMD
                D S ohMD
                D S ohM
                Looks good Gary! Let me know when you need a drive shaft. I opened up a new shop right by Tintmasters.
                I wanna go fast!
                • GrrG
                  GrrG
                  Super victor and fuel rails
                  • MisterCMKM
                    MisterCMKM
                    You should make that thing turn corners instead...
                    Ford is back :)
                    • GrrG
                      GrrG
                      only corners around here are offramps! Not much point in it
                      • MisterCMKM
                        MisterCMKM
                        Come down to the cities and go to an event at DCTC.
                        Ford is back :)
                        • GrrG
                          GrrG
                          No thanks, not even interested
                          • GrrG
                            GrrG
                            80#/ 850cc injectors
                            Should be more than enough corn
                            • legacy-user-351L
                              legacy-user-351L
                              legacy-user-351
                              Well sheesh, we run the same size injectors then... 😄 (okay, so I only run 4 of them...)
                              Looking great Gary, I hope I get to see it run next summer!
                              Turkeylord
                              '05 Yamaha Zuma - Stock
                              • K
                                K
                                I'll go if you go....
                                • MisterCMKM
                                  MisterCMKM
                                  You will never sack up and come down here...
                                  Ford is back :)
                                  • GrrG
                                    GrrG
                                    So this is the harness, it sucked big time to do, but it looks so much better. all done up in heat sleeving an no more corrugated plastic loom, god i hate that shit. I need to pick up a couple parts since I broke 2 of the small metal injector terminals. But its basically done and as good as I could get it. Think I have about $45 in heat shrink in this and have enough left to do a good amount of the engine bay harness as well. Wasnt planning on it but in the back of my mind I could hear Jim telling me "that wiring is fucking garbage" and I didnt want to go through that hours long teasing session
                                    • GrrG
                                      GrrG
                                      Got the longblock together this weekend. Need to get a couple small parts and have the intake milled this week.
                                      • MisterCMKM
                                        MisterCMKM
                                        Looks like a good place for a double pumper!
                                        Ford is back :)
                                        • 63vette6
                                          63vette6
                                          63vette
                                          4150 base? Pfffftttt..
                                          Put a turbo on it, I will give you a 4150 elbow.
                                          BTW: PET braided sleeve is nice.
