  4. Car Updates / Progress
  5. The ugly silver camaro
24 Posts 6 Posters 9.9k Views
  • 63vette6
    63vette6
    63vette
    I hope you destroy that hood and dont try to sell it to some unsuspecting idiot. That hood is a huge pile of shit, glad you are finally getting rid of it.
    • GrrG
      GrrG
      SPRINGS!
      Up to this point, it had some boltons, headers and exhaust, lid, 4.10 gears and a PTC 4500 stall converter.
      [video]http://youtu.be/iQfjyMpjBGw[/video]
      It was a blast to drive but I had once again gathered a pile of parts. So....
      Ported heads, milled to death. 238/246 cam, 13:1 compression, and E85. Shortly after I Also switched to a 3800 stall PTC converter, as with the new power the old 4500 turned into a 5500
      Little idle vid
      [video]http://youtu.be/kgPimwzuuaI[/video]
      Like this the car ran a 13.000@114 on the street tires at a street legal day. I literally was spinning clear through most of 2nd gear.
      SO, i bought some drag radials, and new rims
      With that being the one and only change, the car ran 11.4@120 and i wasnt even pushing it. Still using the LS1 intake which is the most restrictive model there is, and a less than optimal exhaust setup. There is more to be had
      • GrrG
        GrrG
        Though I could have done so much more with that setup, my stupidity and good deals got the best of me
        Light K-member, 35# of weight savings and so much easier to work on
        LS1 back on the floor once again!
        These showed up out of nowhere?
        Then this fell out of the sky
        378" of forged LS3 bottom end. Running the same heads and cam as that is what I spec'd the cam for when I bought it. This is
        Mahle 4.075 forged pistons
        Scat 6.125" h-beam rods
        stock crank
        Good Ls2 style timing set
        the 243 heads that I did some more porting on
        Cometic 4.085x.040 head gaskets
        EPS 238/246 .608" 111+3 cam
        BTR dual springs, ti retainers
        stock rockers with Comp trunion bearing upgrade
        It works out to be 14.15:1 compression, and around 10.55:1 dynamic compression. This will be backed up with a FLT trans stage 5 4l60e with all the good parts, and around a 5000 stall converter
        • MisterCMKM
          MisterCMKM
          Still on a 10 bolt?
          thrash;315544 wrote:
          Ford is back :)
          • GrrG
            GrrG
            yes, that should get replaced sometime next year
            • MisterCMKM
              MisterCMKM
              What is going in?
              Ford is back :)
              • GrrG
                GrrG
                either a 12 bolt or dana 60
                • D S ohMD
                  D S ohMD
                  D S ohM
                  Looks good Gary! Let me know when you need a drive shaft. I opened up a new shop right by Tintmasters.
                  I wanna go fast!
                  • GrrG
                    GrrG
                    Super victor and fuel rails
                    • MisterCMKM
                      MisterCMKM
                      You should make that thing turn corners instead...
                      Ford is back :)
                      • GrrG
                        GrrG
                        only corners around here are offramps! Not much point in it
                        • MisterCMKM
                          MisterCMKM
                          Come down to the cities and go to an event at DCTC.
                          Ford is back :)
                          • GrrG
                            GrrG
                            No thanks, not even interested
                            • GrrG
                              GrrG
                              80#/ 850cc injectors
                              Should be more than enough corn
                              • legacy-user-351L
                                legacy-user-351L
                                legacy-user-351
                                Well sheesh, we run the same size injectors then... 😄 (okay, so I only run 4 of them...)
                                Looking great Gary, I hope I get to see it run next summer!
                                Turkeylord
                                '05 Yamaha Zuma - Stock
                                • K
                                  K
                                  I'll go if you go....
                                  • MisterCMKM
                                    MisterCMKM
                                    You will never sack up and come down here...
                                    Ford is back :)
                                    • GrrG
                                      GrrG
                                      So this is the harness, it sucked big time to do, but it looks so much better. all done up in heat sleeving an no more corrugated plastic loom, god i hate that shit. I need to pick up a couple parts since I broke 2 of the small metal injector terminals. But its basically done and as good as I could get it. Think I have about $45 in heat shrink in this and have enough left to do a good amount of the engine bay harness as well. Wasnt planning on it but in the back of my mind I could hear Jim telling me "that wiring is fucking garbage" and I didnt want to go through that hours long teasing session
                                      • GrrG
                                        GrrG
                                        Got the longblock together this weekend. Need to get a couple small parts and have the intake milled this week.
                                        • MisterCMKM
                                          MisterCMKM
                                          Looks like a good place for a double pumper!
                                          Ford is back :)
