  4. dead car...should be a simple fix??
19 Posts 8 Posters 1.1k Views
  • jct_4628J Offline
    jct_4628J Offline
    jct_4628
    Ok background first.....my blazer has been acting weird (what a suprise)....Every now and then when I punch it, it will cut out for a second then come back and work normal. It has done that maybe 5 times in the last few weeks. Today it did it again, but it wont come back.
    Current situation......car is in the parking lot. When I turn the key it cranks, but wont start. I can keep it cranking but nothing happens. I have had suggestions to check the cap and rotor, the distributer cap, and the coil. Any ideas?
    Jason
    -06 WRX
    -95 CBR 600F3
    701-541-2568
    • L Offline
      L Offline
      legacy-user-131
      besides those i'd make sure it's getting gas
      94 Prelude SI
        yeah sounds like something with the FPR ( fuel pressure regulator)
          blazers are notorious for fuel pumps going out after 100k...... say your prayers cause you're gonna spend 700-800 bucks if you have the dealership replace with an oem pump.
            700-800 .....yeah right go buy a AC Delco Fuel pump and have it installed somehwere else..
            • J Offline
              J Offline
              jake
              What year Blazer is it?
              Check to see if you have spark, and listen to hear if your fuel pump is running when you turn the key on
              My first guess would be the ignition module (under the dist. cap and rotor ~ new for around $30-$40)
              They usually cut out temporarily at high loads or high RPM (due to heat), and eventually go out totally
              Jake
              Jake
                The guy that bought my blazer had the pump go out and it cost him $7xx.00 some bucks for the OEM as I stated.
                I've priced out the pumps before I really don't think you're gonna do it for under 500 bucks parts and labor. BUT, who knows if that is even the issue.
                  I had the same thing happen to my Blazer and it was the fuel pump going out. It isn't that bad for it to be fixed mine costed $600 because I got a whole new gas tank at the same time.
                  • jct_4628J Offline
                    jct_4628J Offline
                    jct_4628
                    so, how do I tell if its the fuel pump? And if it is, do you all think you could talk me through a home replacement? I need my car for work, so please respond fast! You guys rule!
                    Jason
                    -06 WRX
                    -95 CBR 600F3
                    701-541-2568
                    • jct_4628J Offline
                      jct_4628J Offline
                      jct_4628
                      so I just went out (9:00 am) to check if I had spark. As far as I can tell all my plugs are right between the engine and the firewall. So I cant even fucking get my hand back there to get the plug wires off. Why the fuck did I take a job that depends on my pos? Any ideas fs?
                      Jason
                      -06 WRX
                      -95 CBR 600F3
                      701-541-2568
                        thats a chevy engine for ya....pretty sure ur not gettin any fuel tho.....bring it to a shop.
                        • J Offline
                          J Offline
                          jake
                          Again, what year is your Blazer? I'm assuming 4.3 V6. Vortec or TBI?
                          You should hear your fuel pump (a little whining noise in the fuel tank). The pump should run for a few seconds when you first turn on the key, and then go again after cranking for a while. If you want to check the fuel pressure, there should be a schrader valve (looks like a tire valve stem) on the fuel rail up by the injectors. If you don't have a fuel pressure gage, you can put a rag over the valve and poke the center with a screwdriver. It will squirt like crazy if there's any fuel pressure in the system.
                          Jake
                          Jake
                          • jct_4628J Offline
                            jct_4628J Offline
                            jct_4628
                            Jake1995....look at my sig hehehe
                            Jason
                            -06 WRX
                            -95 CBR 600F3
                            701-541-2568
                            • F Offline
                              F Offline
                              fanaticrockford
                              you can also spray some starting fluid in the intake if it fires you have a fuel problem. also check out http://blazinlow.com/
                              • My NOvaM Offline
                                My NOvaM Offline
                                My NOva
                                Check Ur Fuses Allmost All Chevys Have A Main Engine Fuses That Will Let It Crank And Crank And Not Fire Up
                                Hey Tina come get some hamm
                                • dubbsyD Offline
                                  dubbsyD Offline
                                  no, it says that your bike is a 95.. not the blazer. 😉
                                  • jct_4628J Offline
                                    jct_4628J Offline
                                    jct_4628
                                    It was a fuse......fawk
                                    Jason
                                    -06 WRX
                                    -95 CBR 600F3
                                    701-541-2568
                                      well that is good news then.
                                        holy fucking shit....Nova was the only one right!
