  4. Boost controlling
Boost controlling
27 Posts 7 Posters 3.0k Views
  • T
    T
    TRE
    where is the info... i was looking for lol
      Bad93ex wrote:
      Just save your money and pick up a SLS MBC. Cheap and effective.
      True, but if you want to be able to make real time adjustments and change the boost settings from inside the car, an ebc might be better.
      • STiSchuckyS
        STiSchuckyS
        he said he has 400 to spend for boost problems...SLS mbcs are like 40 bucks, i dont think he needs to save
        • T
          T
          TRE
          well once it is set I don't plan on changing it.... that is what i was trying to say... is there certin contorlers that have better responce or lack boost spikes or will a simple boost controler do that for me no problem?
          What are the advantages of the electronic boost controlers?
          • integra_gsr98I
            integra_gsr98I
            If you dont plan on ever changing boost whatsoever, just get an 18 psi spring for the WG.
            • T
              T
              TRE
              can't they dont make one, I have a turbonetics evolution wastegate
              • integra_gsr98I
                integra_gsr98I
                What is the flange like? Maybe you will be better suited w/ a TiAL wastegate. I have never been a fan of turbonetics wastegates.
                • T
                  T
                  TRE
                  I want a tial wastegate, but I already have the turbonetics one, ... is there anything wrong with the turbonetics one? Any info would be great... I am having nick weld a flange on there anyways for the turbo I'm sure it wouldnt be too hard to reweld a flange on there for a tial wastegate... just more money for no reason ya know... but ya give me some info
                  • T
                    T
                    TRE
                    just trying to use what i have I guess ya know...
                    • T
                      T
                      TRE
                      http://i4.photobucket.com/albums/y105/streetcivicsi/T3manifold2.jpg there is a picture of the manifold
                      • T
                        T
                        TRE
                        how accurate are those tial wastegate springs? if i get one that is 17-18psi is it going to be right on the nuts? one more thing, is there going to be wastegate creep without a boost controller?
                        • integra_gsr98I
                          integra_gsr98I
                          That's a 35/38mm flange. Boost control w/ just a WG spring, especially a tial WG, is ROCK STEADY.
                          • T
                            T
                            TRE
                            hum... size wise is there a difference? like will I have a clearance issue with the tial one? cuz this is premade and stuff. Rock steady huh, sounds like the ticket, it will be an extra 150 from what I can tell. so... could maybe do it.
                            • integra_gsr98I
                              integra_gsr98I
                              Tial 38mm should only be 250 some dollars if I remember right.
                              Check w/ straight line for an actual price.
                              • T
                                T
                                TRE
                                well i figure i could sell the other wastegate on ebay for about 75-100 and i was going to spend like 50 on a boost controller... and the tial is about 275 with the spring I need. so about 100-150 extra dollars see my thinking lol
                                • T
                                  T
                                  TRE
                                  Size Difference Anyone?
                                  • PSiedTSiP
                                    PSiedTSiP
                                    bigger=less chance of boost creep and most likely better control...
                                    spanish-rice;237125 wrote:
                                    • T
                                      T
                                      TRE
                                      I would like to know for fit, not for boost control, I know both will be fine for flow cuz I'll be pushin 300hp at the max, I think my 1.3L block can only handle 340 before it is about to break.
                                      • integra_gsr98I
                                        integra_gsr98I
                                        Size wise the tial's are usually smaller than the turbonetics wastegates actually.
                                        • T
                                          T
                                          TRE
                                          sounds like a plan, they have a 17.4 psi spring so I think i will go with that, they also have a 18.84 psi spring.... My fuel is set for 18psi but then i am going to fine tune just a bit, witch spring should i go with?
