Boost controlling
Bad93ex wrote:
Just save your money and pick up a SLS MBC. Cheap and effective.
he said he has 400 to spend for boost problems...SLS mbcs are like 40 bucks, i dont think he needs to save -
well once it is set I don't plan on changing it.... that is what i was trying to say... is there certin contorlers that have better responce or lack boost spikes or will a simple boost controler do that for me no problem?
What are the advantages of the electronic boost controlers?
If you dont plan on ever changing boost whatsoever, just get an 18 psi spring for the WG.
What is the flange like? Maybe you will be better suited w/ a TiAL wastegate. I have never been a fan of turbonetics wastegates.
I want a tial wastegate, but I already have the turbonetics one, ... is there anything wrong with the turbonetics one? Any info would be great... I am having nick weld a flange on there anyways for the turbo I'm sure it wouldnt be too hard to reweld a flange on there for a tial wastegate... just more money for no reason ya know... but ya give me some info
http://i4.photobucket.com/albums/y105/streetcivicsi/T3manifold2.jpg there is a picture of the manifold
That's a 35/38mm flange. Boost control w/ just a WG spring, especially a tial WG, is ROCK STEADY.
Tial 38mm should only be 250 some dollars if I remember right.
Check w/ straight line for an actual price. -
Size wise the tial's are usually smaller than the turbonetics wastegates actually.
TRE wrote:
One more thing what is this thing about wastegate creep or whatever it is called, do i need to worry about that? Worry about my wastegate not allowing my turbo to spool as fast or is that more for non external wastegated turbo set ups?Go with the Tial 38mm with the 18.xx spring. What are you putting this on? You mentioned a 1.3l engine, you will not have to worry about creep with a 38mm gate at ~18psi. This would be a perfect setup for you.
