  4. Boost controlling
Boost controlling
27 Posts 7 Posters 3.0k Views
  • T
    T
    TRE
    I want a tial wastegate, but I already have the turbonetics one, ... is there anything wrong with the turbonetics one? Any info would be great... I am having nick weld a flange on there anyways for the turbo I'm sure it wouldnt be too hard to reweld a flange on there for a tial wastegate... just more money for no reason ya know... but ya give me some info
    • T
      T
      TRE
      just trying to use what i have I guess ya know...
      • T
        T
        TRE
        http://i4.photobucket.com/albums/y105/streetcivicsi/T3manifold2.jpg there is a picture of the manifold
        • T
          T
          TRE
          how accurate are those tial wastegate springs? if i get one that is 17-18psi is it going to be right on the nuts? one more thing, is there going to be wastegate creep without a boost controller?
          • integra_gsr98I
            integra_gsr98I
            That's a 35/38mm flange. Boost control w/ just a WG spring, especially a tial WG, is ROCK STEADY.
            • T
              T
              TRE
              hum... size wise is there a difference? like will I have a clearance issue with the tial one? cuz this is premade and stuff. Rock steady huh, sounds like the ticket, it will be an extra 150 from what I can tell. so... could maybe do it.
              • integra_gsr98I
                integra_gsr98I
                Tial 38mm should only be 250 some dollars if I remember right.
                Check w/ straight line for an actual price.
                • T
                  T
                  TRE
                  well i figure i could sell the other wastegate on ebay for about 75-100 and i was going to spend like 50 on a boost controller... and the tial is about 275 with the spring I need. so about 100-150 extra dollars see my thinking lol
                  • T
                    T
                    TRE
                    Size Difference Anyone?
                    • PSiedTSiP
                      PSiedTSiP
                      bigger=less chance of boost creep and most likely better control...
                      spanish-rice;237125 wrote:
                      • T
                        T
                        TRE
                        I would like to know for fit, not for boost control, I know both will be fine for flow cuz I'll be pushin 300hp at the max, I think my 1.3L block can only handle 340 before it is about to break.
                        • integra_gsr98I
                          integra_gsr98I
                          Size wise the tial's are usually smaller than the turbonetics wastegates actually.
                          • T
                            T
                            TRE
                            sounds like a plan, they have a 17.4 psi spring so I think i will go with that, they also have a 18.84 psi spring.... My fuel is set for 18psi but then i am going to fine tune just a bit, witch spring should i go with?
                            • T
                              T
                              TRE
                              One more thing what is this thing about wastegate creep or whatever it is called, do i need to worry about that? Worry about my wastegate not allowing my turbo to spool as fast or is that more for non external wastegated turbo set ups?
                              • 91nbtsi9
                                91nbtsi9
                                Go with the Tial 38mm with the 18.xx spring. What are you putting this on? You mentioned a 1.3l engine, you will not have to worry about creep with a 38mm gate at ~18psi. This would be a perfect setup for you.
                                • T
                                  T
                                  TRE
                                  better to go with higher boost than lower boost?
                                  • 91nbtsi9
                                    91nbtsi9
                                    Haha, duh! No, depends on what you are turboing, what turbo, etc. Lets hear some details. But definately a tial is the way to go.
                                    • P
                                      P
                                      A TIAL 38mm is plenty big for the turbo you plan on using.
