  4. New D Series Setup
New D Series Setup
23 Posts 13 Posters 1.1k Views
    What are the benefits of this?? I would assume it would spools a little quicker and maybe save some weight.
      The less area the air has to travel the more efficent it is, less pressure loss, quicker spool...
      Less clamps to blow off lol...
        that is awsome
        • sitn2loS Offline
          sitn2loS Offline
          sitn2lo
          very nice..
          Yukon Denali on 22's
            SLS Big Double Backdoor IC from when I put it on a year ago...
            Here you can kindof see the short stubby IC pipe connecting my turbo to the IC.
              with a set up like that do you have to put stiffer motor mounts in so when engine move it doesnt bend all that up?
                Either poly mounts or a hump hose coupler. As you'll notice on the integra it has motor mount inserts.
                  All tacked together.
                    Did this one for D series a few months ago now, but never got around to posting.
                      This is the manifold we use for bolt on style setups. Not quite finished w/ this one yet, maybe tomorrow.
                      • krzydrftr93K Offline
                        krzydrftr93
                        Looking nice...
                        Matt
                        92 Civic HB
                        JDM d15b w/14b@8psi
