  4. My DSM is friggen slow. Any thoughts?
71 Posts 19 Posters 2.3k Views
  • JohnWJ Offline
    JohnWJ Offline
    JohnW
    [QUOTE=D S ohM;181395]DSMlink is awesome if you have the extra money to spend on it. Way better than an AFC. Good choice.
    Ya, I figure since I already have some experience tuning with logs on a computer I should be able to use DSMlink fairly easily. My ecu is already socketed besides. It is expensive but if you remember how many ppls afcs get stolen around here, it evens out dont you think?
    90 Civic DX hatch
    D16a6/y8 mini me
    • JohnWJ Offline
      JohnWJ Offline
      JohnW
      Well, hopefully I'll see some ppl at the track and decide to be social. Maybe you guys can give me some tips on driving and whatnot.
      90 Civic DX hatch
      D16a6/y8 mini me
      • D S ohMD Offline
        D S ohMD Offline
        D S ohM
        I take mine out every night to avoid that issue.
        I wanna go fast!
          I'd put the stock ECU in it.
          My old 1g ran 13.5 @ 95 w/ a 8.8 1/8 mile with exhaust a UICP pipe and a boost controller. By the end of the summer I had it, it was running 8.5 1/8 miles but I was back in Minot so it never made it back down to the 1/4.
          • JohnWJ Offline
            JohnWJ Offline
            JohnW
            D S ohM;181405 wrote:
            [QUOTE=JohnW;181396]
            I am inattentive, and lack discipline.
            90 Civic DX hatch
            D16a6/y8 mini me
            • D S ohMD Offline
              D S ohMD Offline
              D S ohM
              JohnW;181407 wrote:
              [QUOTE=D S ohM;181405]
              I am too for the most part, but that is a little investment that i would like to protect.
              I wanna go fast!
              • JohnWJ Offline
                JohnWJ Offline
                JohnW
                my 14.3 was at 96.7 mph, so is that about right or what does that mean. does that mean I suck at driving?
                90 Civic DX hatch
                D16a6/y8 mini me
                • DrifterExtremeD Offline
                  DrifterExtreme
                  yes... j/k
                    What do your 60fts look like?
                    • treimcheT Offline
                      treimcheT Offline
                      treimche
                      If you're on a stock clutch, and can't launch very hard then thats probably the biggest factor in you running 14.3. Figure for .1 sec faster to the 60 foot mark, normally will net you about .2 sec faster in the 1/4 mile. So depending on your launching ability, clutch holding or slipping, and tires spinning from being wet, you could be right on par.
                      DSMLink is pretty good for a cheaper standalone style engine management. It's still not a full stand alone, but it is extremely easy to use and has tons of support.
                      Troy
                      2009 Yamaha R1
                      2002 WRX
                      2001 Toyota Tundra
                      2001 Yamaha R6
                      1988 Yamaha YSR 50
                      2003 XR50
                      • JohnWJ Offline
                        JohnWJ Offline
                        JohnW
                        I don't know what the 60ft was, I didn't keep the timeslips 😞 I'm going to try and focus on getting off the line better this weekend, hopefully my times will improve as a result. That time was from my first time out at the track so I'm sure I was n00bing it up something fierce.
                        The way I figure, DSM link, actually having a dedicated user interface can't be any harder than what I'm doing now, and god knows theres more support. It of course has the ability to change maps but the real bonus is that it contains all of the little addons that you can put into the stock program, except without inputing code, editing hex, or remapping memory addresses. A definate plus. I think an advantage over the other standalone solutions is that DSMlink is made for one car specifically, even between the 1g and 2g, so there is no fiddling around or anything, it just works.
                        90 Civic DX hatch
                        D16a6/y8 mini me
                          are you dumping the clutch at 4k or slipping it? my 1 tip: no lift shift into 3rd and 4th..
                          • JohnWJ Offline
                            JohnWJ Offline
                            JohnW
                            I was dumping it. Ridin Rails gave me some tips that I plan to implement. I'll try no lift on 3rd and 4th as well.
                            90 Civic DX hatch
                            D16a6/y8 mini me
                              Don't no lift on 3rd and 4th and don't shift at redline when shifting into 3rd or 4th gear. The little 14b turd doesn't make power all the way up top.
                              • mr.98gsxM Offline
                                mr.98gsxM Offline
                                mr.98gsx
                                ^That's true. If you are trying to improve your time just buy more go fast parts. I'd also look into getting it professionally tuned.
                                gotta pay to play man
                                  I usually slipped it around 5.5k and shifted about 6.8-7k. Seemed to work about the best for me.
                                    the 14b works, slowvo on here ran 12.1 with a 14b back in the day. You'd be better off putting the stock ECU back in the car w/ the stock fuel maps, etc and shifting before redline. I'd shift closer to 6500 rpm in the higher gears.
                                    • mr.98gsxM Offline
                                      mr.98gsxM Offline
                                      mr.98gsx
                                      ^slowvo probably didn't have a stock motor though too did he? And I'd guess he's running aem
                                        slowvo had a stock 2g/1g motor with an AFC.
                                        • mr.98gsxM Offline
                                          mr.98gsxM Offline
                                          mr.98gsx
                                          ^12.1 1/8 mile maybe haha. I don't believe anybody ran a 12.1 1/4 mile on a stock motor with a 14b.
