  3. Track Talk
  4. auto x!!
auto x!!
170 Posts 30 Posters 23.1k Views
  • R Offline
    R Offline
    revolutionz_s13
    lol...i see now that came out kinda wrong (sometimes i forget you cant have a "tone of voice" on the internet)...but you know, maybe i will run a safc in mine, so i can continue to improve on my "turbo master" status :icon_cheers:
    > MisterCMK;207559 wrote:
    > Of course the Astrovan won. I've seen one-legged children on tricycles beat v6 mustangs.
      Back on topic, what class would I be in..
      CRX, B20/vtec, intake, exhaust...the usual stuff, bushings, coilovers and stuff like that...street tires...
      • zbrownZ Offline
        zbrownZ Offline
        revolutionz_s13;196230 wrote:
        but you can control wheelspin with throttle control, you dont have to bury your foot every time you press the gas pedal....
        That i would have to see....
        may be possible to an extent with a small turbo like that
        Matt is right, even on my car the 57trim would fall off up top
        rx7-8.89@157mph
        12v dodge, twins
        • R Offline
          R Offline
          revolutionz_s13
          well, fabers turbo(AMS GT32) is roughly equivalent to a garrett 50 trim, .60 a/r. Which is smaller in size and probably less efficient (AMS wont give out the exact specs) than a GT3076R, .82 a/r. Faber has no problems up top, I dont think I will have to worry about that. There is a guy on ka-t.org that is making 417whp with a similar setup to mine @ 19psi with a gt3076r .82 a/r.
            my gt32 doesnt fall off up top! the turbo has a gt3251e CHRA, with custom precision housings. IMO the turbo is like a 57trim out put wise, while spooling like a 50trim(all refering to t3/t4, .63AR)
            and WTF do you mean buy 57trim. you need to be WAY more specific about those things. There are thousands of differant 57trim turbos on the planet.
              bubba you will be in SM due to motor swap.
              that makes 5 of us in SM for next year.
              • R Offline
                R Offline
                revolutionz_s13
                assuming i get my POS together and down to the cities to get tuned....
                  he means a t3/t4 57 trim... the "tufte turbo". Even I knew that.
                    OMG you think I am THAT dumb? Of course i knew what he meant.
                    I am just saying what i said. my dad gets some people every once and while that come in asking for a 50 or 57trim. my dad knows what they are. but is always like which one, there is thousands and gets the dumbest look on the kids faces.
                      lol, you confuse me faber, if you didn't mean it, why did you say it, and go into detail?
                      • R Offline
                        R Offline
                        revolutionz_s13
                        ahahahahah, have you ever met faber? and did you really have to ask?:D
                          What do you mean go into detail?
                          I said it because i was trying to make a point.
                            So basically im fucked, lol...
                            • zbrownZ Offline
                              zbrownZ Offline
                              like faber said, trim is nothing more than (ind^2/exd^2)*100
                              57trim is just a common name given to a popular T04E compressor
                              My gt42 has a 53 trim compressor and 84 trim turbine....
                              if you have the trim # and either ind or exd it is easy to find the other
                              rx7-8.89@157mph
                              12v dodge, twins
                              • DrifterExtremeD Offline
                                DrifterExtreme
                                now see i'm running the same turbo same specs, i got the atp 3" v-band.
                                now with my motor i should see full boost buy say 4800ish give or take based on my monster manifold. now i rev to 9k so i will have a power band.
                                but unlike you i will not make near the torque you will, so all i'm saying is that you need to look at the fact that it will just make it harder fo ryou to drive the car to it's potential. but i spose we will see next year.
                                • zbrownZ Offline
                                  zbrownZ Offline
                                  kinda curious
                                  so lets say 400whp....
                                  how much boost would it take Matt to make that? and how much torque
                                  vs
                                  how much boost with the KA, and how much torque
                                  with identical turbos; the ones you stated above
                                  rx7-8.89@157mph
                                  12v dodge, twins
                                    DrifterExtreme
                                    gt3076r, 18 lbs , high 200's for torque.
                                    now this is with a small .48 turbine
                                    http://www.s2ki.com/forums/index.php?act=module&module=gallery&cmd=si&img=397509
                                    • R Offline
                                      R Offline
                                      revolutionz_s13
                                      on the KA, you will see ~400whp @ roughly 19-20psi, hitting full boost by roughly 5k-6k rpms(dont quote me on that....) depending on setup. That should net you depending on tuning, about 350ft-lbs of torque.
                                      this would be the gt3076r with the .82 a/r turbine
                                      here is a dyno from some guy down in georgia that has a similar setup to mine....
                                        Ivan has 40psi on his gt42 sooner then 6k.
                                        you should have around 20psi at like 4k.
                                        • R Offline
                                          R Offline
                                          revolutionz_s13
                                          eh maybe...like i said not too sure about that...i thought it would be about 4200-4400 from when i did all the calculations from the compressor map, but i wasnt sure if i figured right.
