  3. Track Talk
  4. auto x!!
auto x!!
170 Posts 30 Posters 24.6k Views
    you do remember how fast my turbo spools. and yours should spool around the same as mine does. The DBB should somewhat make up for you having a .82ar
    • DrifterExtremeD Offline
      DrifterExtreme
      ball bearing doesn't mean faster spool...... you should know that faber...haha
      • R Offline
        R Offline
        revolutionz_s13
        well in a round about way it does....it takes less force to spin a DBB cartridge than it does to spin a ceramic journal bearing cartridge...which means the turbo wheel will reach higher speeds faster...which means the compressor will flow more air faster = boost faster.
        > MisterCMK;207559 wrote:
        > Of course the Astrovan won. I've seen one-legged children on tricycles beat v6 mustangs.
          Yes, i know this. DBB makes the turbo more efficient, also get more devoted lubrication and coolin. and then what nate said.
          I would be hard, but if you have 2 identical turbos one with journal bearing and the other with the DBB, 95% of the time the DBB will spool faster then JB turbo,
          WITH ALL THINGS BEING EQUAL
            DrifterExtreme
            borg warner? ....
            haha ok now i'm just being diffecult...
            • zbrownZ Offline
              zbrownZ Offline
              thats interesting, thanks
              for comparison here is what your typical 13b rew will do
              here is a graph of a typical single setup.... gt 3582r---1.06a/r
              13-15 psi, 320-340lb-ft, 400rwhp, full boost 4k
              you need alot bigger turbo for the same power.......
              rx7-8.89@157mph
              12v dodge, twins
              • N Offline
                N Offline
                nvrdone
                Ok, back to the class/setup thing.
                1988 RX-7 GXL - Full suspension, coilovers, bushings, sways, everything.. Rebuilt 6-port n/a, itb's, prolly microtech lt8, cage..
                guessing sm as its still a dd setup I hope :drunken_smilie:
                2000 SC1 - S1 SPL car, 136.9db atm
                1988 RX-7 GXL - waiting for my lazy ass to finish high comp turbo swap
                • GarageAlchemistG Offline
                  GarageAlchemist
                  id like to see that...
                  97 GTi, 03 KJ
                  • N Offline
                    N Offline
                    nvrdone
                    Hopefully by next summer you will. Almost have enough saved for the rebuild.
                      damn sounds like the nice set-up! what was your name again?
                      • JN210J Offline
                        JN210J Offline
                        JN210
                        I will be running my stock setup(as if I have another anyway lol).....I just want to get a feel for the sport first, Im going to have some fun and learn a little bit.
                        *1989 Nissan 300ZX Z31 *
                        > DelSlow;262050 wrote:
                        > I like the new JN210
                        • zbrownZ Offline
                          zbrownZ Offline
                          for a whole 180 rwhp if you are lucky on a tuned S4 stock port 6 port......
                          rx7-8.89@157mph
                          12v dodge, twins
                            Not everyone wants an enourmous turbo that needs anti-lag to spool and a million hp...some want something that'll work good for auto-x
                              180hp is just fine for auto-x. driver skill and supension are WAY more important then power.
                              • zbrownZ Offline
                                zbrownZ Offline
                                god....
                                if i put a turbo as amall as fabers on my car it would act like an NA car....... there would be boost all the time, way more than fabers car even
                                all i am saying is that a rx7 with even just the stock turbo system has waaay more potential than a NA one in anything.... and that he should look into that as it is cheap and very effective
                                I never said a word about a large frame turbo did i??
                                I dont care what anybody says.... my car even with a very large turbo is going to beat an NA 7 even in auto-x, not doubt, if the rest of the cars are set up the same, same driver skill
                                OH and bubba, so you know i pulled a 1.5 60ft without antilag, and i can spool a 42 like a 2jz... hmm
                                rx7-8.89@157mph
                                12v dodge, twins
                                  i dont know about that one
                                  • N Offline
                                    N Offline
                                    nvrdone
                                    Sorry, I'm rebuilding TO port it. Should make 200+whp, not telling how I'm rebuilding though or porting. Its my secret................. 😄
                                      high comp pistons, forged rods and mill the head?? lol
                                        DrifterExtreme
                                        rebuilding - prolly using tools and some vasiline?
                                        porting - prolly a template and a die grinder?
                                        sorry if im a smartass, but an n/a rx-7 is liek a b16, yeah it makes cool noises and rev's to the moon, but it is still slow as balls.......
                                        • JohnWJ Offline
                                          JohnWJ Offline
                                          JohnW
                                          I'll be autoxing for sure. My current setup is
                                          90 Civic DX hatch
                                          d16a6 w/ MPFI conversion
                                          ebay header and exhaust 2.25"
                                          generic filter, no intake pipe
                                          busted ass suspension w/ ebay coilovers
                                          stock brakes
                                          Hopefully by spring:
                                          cam for D16a6 or mini me (mad vtak yo)
                                          fuel management (v/afc or uberdata w/ ostrich)
                                          same exhaust
                                          ebay cold air intake
                                          better suspension maybe KYB GR2 or AGX w/ proper lowering springs instead of sleeves
                                          upper and lower stiffening bars, cpillar bar
                                          matching steel wheels( ive got 4 different ones on there now), better tires
                                          gotta do some research but the brakes will be upgraded too
                                          This car will be useless in the 1/4 (I know, enjoy my 15s right?) so I'm gonna try my hand at turning 🙂
                                          90 Civic DX hatch
                                          D16a6/y8 mini me
