  3. Run Your Mouth
  4. My Improperly set welder...
39 Posts 13 Posters 4.8k Views
    bubba;212034 wrote:
    joel just cant let shit go, as i'm sure everyone has been able to tell by now....
    And neither can you guys...
    It is the pot calling the kettle black here. You do the same shit that you complain about Joel doing...
    • ParkerP Offline
      ParkerP Offline
      Parker
      Afsil80;212039 wrote:
      Just remember, God REALLY invented heat wrap to cover up bad welds...
      EDIT: Huge turbos are also good distractions.
      prove it
      10 Jeep
      10 F450
      08 F250
      05 F350
      86 rx7
      70 F100
      63 Olds
      > BlueSRT0483;244555 wrote:
      > Trafik Jamz;260984 wrote:
      > You are right Parker.
        QFTMFT
        • Afsil80A Offline
          Afsil80A Offline
          Afsil80
          Parker;212046 wrote:
          prove it
          Prove what, that there's ugly welds beneath that heat wrap? That's why we did it, hahaha. It was the only Pro Hot Rod car with heat wrap this weekend.
          The manifold holds up fine, it just doesn't look the best, haha.
          -Peter
          1991 240SX
          • ParkerP Offline
            ParkerP Offline
            Parker
            no prove that god invented heat wrap... you silly...
            10 Jeep
            10 F450
            08 F250
            05 F350
            86 rx7
            70 F100
            63 Olds
              He is from the south, whattya expect?
              • zbrownZ Offline
                zbrownZ Offline
                DrifterExtreme;212028 wrote:
                ok now to bring some drama back into this thread....
                Zac, your tig welds suck balls.
                :faq-roll:
                stupid not to suck a ball or two once in awhile :drooling:
                rx7-8.89@157mph
                12v dodge, twins
                • FG2F Offline
                  FG2F Offline
                  FG2
                  Here is my question. I know nothing about blonde asian women, baseball, or welding. Even though Joel's welding yields some jizzum splatter, does it effect the strength of the weld? For the flange on the downpipe, would a 'non jizzum splatter' weld offer the extra NEEDED strength, or would it be ok? I ask in all seriousness, cause besides not being the most attractive, I don't see why it wouldn't do the task... Again, I am a welding noob and have utmost respect to anyone that can make a straight bead.
                    ^From my understanding, it is more that the machine was not set up properly for the welding that it was used for. The splatter is material that could have been part of the weld. For the exhaust welding, its not a problem, I have seen MUCH worse work from local exhuast shops.
                      It had to do with the fact that I had only 700 PSI of gas left, and I was at the end of a small spool of wire(meaning the wire comes out of the tip of the gun very unevenly.) Settings had nothing to do with it, otherwise the weld itseld would look like shit.
                      • ParkerP Offline
                        ParkerP Offline
                        Parker
                        i did those welds on with the remainder of the wire and a diff tank of gas that had only 500ish psi left.... i just played around with the wire speed a bit.... and i am no MIG welder....
                        10 Jeep
                        10 F450
                        08 F250
                        05 F350
                        86 rx7
                        70 F100
                        63 Olds
                          Troof, I was there
                          • zbrownZ Offline
                            zbrownZ Offline
                            Joel;212205 wrote:
                            It had to do with the fact that I had only 700 PSI of gas left, .
                            LOL are you serious???? really now are you serious??
                            drrrrrrrrrrrrrr hhmmmmm that flow meter next to the cylinder pressure gauge does nothing
                            a cylinder with with only 300psi left is going to hold a steady CFH of gas flow.... it will stay consistent and not fall off till it cannot the support the level of gas flow you are asking for........... which is far far south of 700psi
                            lol god that is fucking funny...... we change all our $70 worth of shielding gas out when it gets below 1000psi because it makes my welds look like dog shit
                            I thought you go to NDSU........... pay more attention in the fluid/gas dynamics section of your physics class
                            rx7-8.89@157mph
                            12v dodge, twins
                              +1.. I could see if there's a diff psi flowing, but amount left shouldnt matter, as long as it comes out at the same rate...
                                So i made a weld with some fucking spatter. OMFG, Lets die. I made a shitty weld, does that make you guys happy. Now get over it.
                                  Ur the one that brought up another whole thread about it, cuz u couldnt let it go....
                                  • no_slow_clapN Offline
                                    no_slow_clap
                                    this thread is retarted
                                    EVOLUTION VIII
                                      and u decided to bring it back from the dead why?
                                        http://www.youtube.com/watch?v=Z1xqm7gmBjs
                                        http://www.youtube.com/watch?v=IFX4zhNubBI
