  4. New Stuff
New Stuff
461 Posts 56 Posters 74.5k Views
  • zbrownZ Offline
    zbrownZ Offline
    epic^
    rx7-8.89@157mph
    12v dodge, twins
    • zbrownZ Offline
      zbrownZ Offline
      Well getting more done
      I am very pleased with how the new front end is coming together with the new and improved radiator and the addition of a FMIC (hope GSR is happy 🙂
      I have gained another 3" of room forward......... and only two bolts to remove the IC, and only two bolts to pull the radiator (holes not drilled for that yet)
      the rad sits on a 1/2" pad of rubber
      rx7-8.89@157mph
      12v dodge, twins
      • funky_monkey58F Offline
        funky_monkey58
        I approve of this new upgrade.
          Yay!
            Holy shit, your going to have an empty engine bay!
            • z31Z Offline
              z31Z Offline
              z31
              Is this a drift car?
              • zbrownZ Offline
                zbrownZ Offline
                Yeah much room, haha
                And why drift car?
                rx7-8.89@157mph
                12v dodge, twins
                • z31Z Offline
                  z31Z Offline
                  z31
                  And why drift car?
                  Because anyone in the right mind racing in the 1/4 would install a cage in there car before adding more power.
                    drift cars need cages too...
                    • zbrownZ Offline
                      zbrownZ Offline
                      Might get around to a cage
                      rx7-8.89@157mph
                      12v dodge, twins
                      • capitljC Offline
                        capitljC Offline
                        capitlj
                        Looking good as usual mister Brown.
                        > Mitch Hedberg wrote:
                        2004 Impala LS 3.8
                        • kylushK Offline
                          kylushK Offline
                          kylush
                          Looks sick, those heads look really nice!
                          1998 Z28 Camaro
                          • zbrownZ Offline
                            zbrownZ Offline
                            thanks
                            you should do a truck manifold setup on yours?
                            rx7-8.89@157mph
                            12v dodge, twins
                            • kylushK Offline
                              kylushK Offline
                              kylush
                              haha yes I should... Finally done with school and got a job in Watertown so hopefully I'll have some money and time to throw at it in the next couple years. Got a dyno and a very good tuner nearby from what I hear
                              1998 Z28 Camaro
                              • zbrownZ Offline
                                zbrownZ Offline
                                Yeah andy is good shit
                                rx7-8.89@157mph
                                12v dodge, twins
                                • capitljC Offline
                                  capitljC Offline
                                  capitlj
                                  So intercooler + lower static compression = moar boost?
                                  2004 Impala LS 3.8
                                  • zbrownZ Offline
                                    zbrownZ Offline
                                    should make alot more power at the same boost, or atleast put it to the ground with the good converter now
                                    but yeah will be able to run as much boost as that little turbo will support anyway
                                    Got my trans from Josh at Kentucky Turbo.... he had it built for his 1000hp build but decided to go 4l80 instead
                                    it is fresh with good stuff and a brake, I shouldn't have to worry about breaking it anytime soon
                                    the ratio of low gear should really help me with traction, and let the engine load up better in my light car
                                    nice and light too 🙂
                                    rx7-8.89@157mph
                                    12v dodge, twins
                                    • zbrownZ Offline
                                      zbrownZ Offline
                                      and since i am an idiot that didn't post it up, it is a powerglide
                                      rx7-8.89@157mph
                                      12v dodge, twins
                                      • z31Z Offline
                                        z31Z Offline
                                        z31
                                        Need more info on the glide. ????
                                        • zbrownZ Offline
                                          zbrownZ Offline
                                          the glide is
                                          RMVB
                                          pro tree brake
                                          turbo input
                                          1.76 straight cut with stock carrier.
                                          8 clutch high gear
                                          Ok now i realize 98% of you guys will hate this, really i do, so it is alright to bash 😉
                                          i just get carried away when i start messing with aluminum because it is so fun, and i had a big hole already
                                          I need to do some trimming yet, and i will probably paint it all black
                                          rx7-8.89@157mph
                                          12v dodge, twins
