  4. New Stuff
New Stuff
461 Posts 56 Posters 74.6k Views
    anytime the bov will be open the meth shouldnt be spraying iirc
      Well what is this kits method of activating the solenoid?
      • zbrownZ Offline
        zbrownZ Offline
        ok so I didn't get to go the track the other weekend like i had planned on because the fuckers didn't get my windshield done, so that pist me off
        so hopefully get there for the next street legal
        anyway, just got my boost controller on. It is a hallman, and paid a little extra for the ceramic ball and extra spring
        I didn't think the car could spool faster but i can definitely tell it does with the addition of just the BC
        Bumped the car to 10psi now, honestly can't believe how much power these motors pick up on every pound of boost, it is nuts
        as always, i like it nice and simple
        and some will probably hate on me for this but whatever
        my aluminum hood had a nice dent in it.... so i got rid of it.... and helped evacuate air in the process (thanks parker, haha)
        FYI this picture does not lie....
        with tape strips hanging off the edge of the vents you can very easily tell that there is a good volume and velocity of air coming up and out the vents when you are at speed
        it always makes me LOL when people jack the back of the hood up and think that is going to help anything.....
        and it gives the gawkers an idea what is under the hood, haha
        needs some actual paint now
        rx7-8.89@157mph
        12v dodge, twins
          Fucking intercool that thing already.......
          • zbrownZ Offline
            zbrownZ Offline
            why? I have my big nozzle now, and my IAT's run at or below ambient air temps with the meth injection
            I spose i should get a screen shot of a log so you believe me
            rx7-8.89@157mph
            12v dodge, twins
              aliengotpsi
              do a 1st ------> 4th gear pull , what are your intake temps after that on a day its 85 degrees out.
              Kevin Smith
              Straightlinedetailing.com
              • beachbum_jonB Offline
                beachbum_jon
                what is up with your front bumper?
                -John Adams, 1735-1826-
                  Hmm...looks like the hole is about as big as an IC....hmmm I wonder??
                    beachbum_jon
                    hmm...that is what i was thinking at first, then i remembered that he going the water meth route vs. IC
                    Oh and zac, what is the fitting just before the inlet of the compressor for?
                      And then you remembered he used to have a GT42/13B setup...fail.
                      • zbrownZ Offline
                        zbrownZ Offline
                        for a pre turbo injection nozzle
                        s
                        i was in the fargo the last couple days, i will do a log with a screen shot
                        and i have 3 gears...
                        rx7-8.89@157mph
                        12v dodge, twins
                        • zbrownZ Offline
                          zbrownZ Offline
                          ok did a log this afternoon
                          i guess i lied a bit, it gets 25-30* above ambient
                          not to worried though because it is running very strong like it is.... i am on E30 with a 10.3:1 CR motor and some decent timing as you can see without any problems
                          for the HP level it is at i should probably be running two 8 ghp nozzles not just one, but it runs really well right now so
                          if you look at the log times from the beginning to the end you will see it took right at 7 seconds for that pull... i rolled into it a little bit so i didn't spin. And i didn't top 3rd out because that is too sketchy on the my road. The 2>3 shift puts you right in the 95-98mph area
                          Boost is just a PID and that is why it is sort of unstable, if you look at the MAP you can see how stable the boost actually is
                          oh and i heart HPT
                          rx7-8.89@157mph
                          12v dodge, twins
                          • zbrownZ Offline
                            zbrownZ Offline
                            and yeah, the 65lb injectors are mostly done there
                            no injection gets me 180* or a little better on the IAT's
                            i have the tune setup to pull alot of timing if the IAT's go up so it should be fairly safe, and i have a pressure gauge in the car in the meth line so i can see that additionally
                            rx7-8.89@157mph
                            12v dodge, twins
                            • zbrownZ Offline
                              zbrownZ Offline
                              that is gay, how come they don't get bigger when you click on the pic? can't see any of the numbers
                              rx7-8.89@157mph
                              12v dodge, twins
                              • zbrownZ Offline
                                zbrownZ Offline
                                quadruple post FTL
                                rx7-8.89@157mph
                                12v dodge, twins
                                  i think you should buy bigger injectors and an intercooler. 😉
                                    some could say the same to you 😉
                                      you're right.
                                      how about this...
                                      i'll buy bigger injectors and an intercooler if zac does too. 🙂
                                      • zbrownZ Offline
                                        zbrownZ Offline
                                        integra_gsr98;314069 wrote:
                                        you're right.
                                        how about this...
                                        <u>i'll buy bigger injectors and an intercooler if zac does too</u>. 🙂
                                        K deal.....
                                        First, just installed some new ID1000's...... going to switch to E85 and maybe bump the boost up till the tranny or converter goes
                                        I have a date on the dyno Friday with Andy
                                        got some new 26x9 slicks..... ordered some matching 15" FNs but they are backordered till Dec. so i canceled that......... so now i guess i will mount them on my OE 6" wheels. Hopefully i do not end up in the wall
                                        and last, a project for the winter, probably my best buy ever on Ebay. It is Wheel to Wheels inventory (the rotax supercharger people)...... Garrett core and no china craps welds.... $40..... they didn't to a good job listing there stuff
                                        rx7-8.89@157mph
                                        12v dodge, twins
                                          that intercooler for that price is bananas. sweet mang!
