  4. Car Updates / Progress
  5. Project Time Attack Miata
70 Posts 28 Posters 20.9k Views
  • inspector01I Offline
    inspector01
    Get it done for BIR, shit load of testing time for pretty cheap...
    PVC Squad Member #1
    • BookemB Offline
      BookemB Offline
      Bookem
      PSI2HI;309074 wrote:
      Not a clue. If i remember correctly it weighed in the 2140lb range stock.
      Rear brake rotor, pads, and driveshaft showed up today. Had to pickup a new longblock as the last swap suffered fron thrust bearing failure which in turn salvaged that longblock. Dropped off the other motor a week ago, may possibly see it back this week, then start assembling this weekend if all goes as planned.
      Did you have 1.8 or 1.6? I still have one sitting around complete throttle body to clutch I'm looking to get rid of.
      Legacy GT
      Gmc Suburban
      Hallorann: Fargostreet?
      Hallorann: No, I ain't.
        If it was only that easy it'd have been done long time ago but we've been slammed w/ work this spring a top of the new development and testing little time is left come end of the day/week.
        It's a 1.8
          Getting closer:
            do you have the onl exhaust from this car by any chance? I am in need of one
            • Chance91C Offline
              Chance91C Offline
              Chance91
              Hate to tell you this, Nick, and you probably only know, but if you've got the original 5-speed you'll be very luck to last a single track day before it shreds its gears. I'd really look into a SE/LE 6-speed. The MSM unit is nice for its shot-peened gears, but I'm just unhappy as hell with mine. Really bad shifting attributed to an improperly designed shift gate, and syncro key retardation. I am going to use my old 6 to work on figuring that out. MER racing has syncro's/keys they designed to help fix the problem.
              Bob Bundy has managed to put down 350 something through a 6 without grenading it, however the 5 speed stories blowing up from 250ft lbs of tq on up are endless.
                Miata Guru.
                  I am well aware of the 5 spd trans issues and honestly dont really care if it blows up, its an easy swap and the clutch will need to be replaced once i turn the boost up anyway.
                  Sounds like you've been doing a little to much forum reading... I like to do things from experience not from reading and will approach the issue once its in front of me.
                  • Chance91C Offline
                    Chance91C Offline
                    Chance91
                    Eh, if you say so. I've not blown up my own 5 speed yet, but I've been at a few track events where its happened. You're right though, at least its an easy enough swap.
                    I'm not a heavy track guy though, I'm hoping to get deeper into the sport in the next year. Been to a lot of tracks and events, but I've only run a handful myself.
                    Anyway, I love the project, wish you luck on it.
                      I dont.
                          Great #'s Nick!!!
                          • zbrownZ Offline
                            zbrownZ Offline
                            nice!
                            wish it was layed over RPM instead of MPH so you could see how it spools
                            rx7-8.89@157mph
                            12v dodge, twins
                            • BookemB Offline
                              BookemB Offline
                              Bookem
                              zbrown;314373 wrote:
                              nice!
                              I'm glad you pointed that out, I was wondering......
                              Legacy GT
                              Gmc Suburban
                              • 91nbtsi9 Offline
                                91nbtsi9 Offline
                                91nbtsi
                                Holy, nice!
                                [email protected] -- DSM
                                07 Mega Cab 5.9 CTD
                                  Great numbers!
                                  • fdfreakF Offline
                                    fdfreakF Offline
                                    fdfreak
                                    very nice. I saw you driving it around last night. I was in the blue fd next to you on main.
                                    12.645@118mph 12.6psi
                                    • zbrownZ Offline
                                      zbrownZ Offline
                                      hey what did this do today?!?
                                      this thing is pimp, hope it ran well granted it isn't setup for drag
                                      rx7-8.89@157mph
                                      12v dodge, twins
                                        I rolled out there for a little while. People were saying 11.6.
                                          11.3 with alien driving.
