  4. Winter mods 2009-10
Winter mods 2009-10
98 Posts 39 Posters 8.7k Views
  • dubbsyD Offline
    dubbsyD Offline
    dubbsy
    KA-T_240;297047 wrote:
    Isn't that overkill for a lil CRX
    dude, endos!
    1995 Mustang
    CAI, rimz, and springs.
    • BassplayerB Offline
      BassplayerB Offline
      Bassplayer
      Yes :icon_rr: but it's not my DD. Having a 200hp motor in that car is overkill, and that's exactly what I'm going for haha Also I've just always had a place in my heart for pimp wheels with really nice brakes behind them.
      Oh yeah and I just bought the brakes so they will be on their way Monday! There goes all my Christmas $.
      1995 GMC Sierra
      • zbrownZ Offline
        zbrownZ Offline
        Bassplayer;297049 wrote:
        Having a 200hp motor in that car is overkill, and that's exactly what I'm going for haha$.
        yes... soooooo overkill
        rx7-8.89@157mph
        12v dodge, twins
          what size wheels will u have to run? 15's are about perfect imo.. anything bigger than 16's look just plain gay...
          I think DA brakes with good pads/rotors will be good enough, if not i've seen ppl make prelude brakes fit... also a lot cheaper...
            BassplayerB Offline
            Bassplayer
            zbrown;297054 wrote:
            yes... soooooo overkill\
            Ha yeah I didn't really mean that like literally. It's only ~8.5HP/lb, hopefully less than 6 with nitrous. I hope to be bringing this car to school with me in Ohio over Spring break, and racing it at Mid Ohio Speedway in the summer. It's not made to be a suppidly overpowered Honda, just cheap, fast, and reliable.
            You have to run 16's on them. I'll be running 16X7 +35 Desmonds. I got a really really good deal on them that I couldn't pass up. Like I said I'm a sucker for good brakes, and these calipers also fit 11" rotors so I can always switch to those if I feel like running a 15" wheel.
            1995 GMC Sierra
            • XJHEADX Offline
              XJHEADX Offline
              XJHEAD
              XJHEAD;296351 wrote:
              Will be doing the following;
              Mini-tub to get some 315-60-15 Radial tires to fit.
              Crank trigger for the ignition.
              Would like to;
              Possibly upgrade to DFI GEN VII fron GEN VII
              Get rid of the two electric fuel pumps Weldon 2035 and the ACCEl pump and get a belt drive.
              Drop fuel pressure from 60 psi to 43 psi and get rid of the 160 lbr's and put in some 225's
              2-speed 400 or a glide
              will add to the list later.
              The mini-tub kit showed up and the tires are on order. Here is a picture of a 315 vs a 325, big difference.
              7.64 @ 187 3400 lbs. on KORN
              TTSBF
              RTCTTFMF PTOSITW
              • DaveHD Offline
                DaveHD Offline
                DaveH
                I think you meant lb/hp. 🙂 Otherwise you are in top fuel dragster territory.
                DaveH
                '94 Supra- 7.77 @ 176mph
                • zbrownZ Offline
                  zbrownZ Offline
                  holy balls, what is the OD difference on those
                  edit saw it was only 2" difference, looks like more
                  rx7-8.89@157mph
                  12v dodge, twins
                  • z31Z Offline
                    z31Z Offline
                    z31
                    How is this tire change going to be gearing wise?
                    • XJHEADX Offline
                      XJHEADX Offline
                      XJHEAD
                      It will be a like a 2.87 gear. If I want it to be the same I would have to get some 3.31 gears. I'll worry about a gear change later if needed. I think I'll be ok with what I am running. I need the extra gearing to be the first in the 180's anyways..:icon_rr:
                      TTSBF
                      RTCTTFMF PTOSITW
                      • z31Z Offline
                        z31Z Offline
                        z31
                        Fidanza 11lb aluminum flywheel
                        South Bend DXD stage 5 clutch
                        Balance clutch and flywheel as an assembly
                        Intercooler and piping install
                        Blow off valve
                        88t front rotors and twin pistion calipers (bigger)
                        88t rear calipers and vented rotors (bigger)
                        88t rear control arms :icon_bigsmurf:
                        • 00Ws6TransAm0 Offline
                          00Ws6TransAm
                          Grr;296394 wrote:
                          finish wiring, fuel system, finish my headers, get the turbo spinnin (oil lines) and then go destroy the rear axle so i can put a 8.8 in and 275 drag radials. Then it should pull the wheels...
                          Regret abandoning your LS motor yet?:)
                          Ill have to check your car out, still havent. WE may even have to line them up.
                          • zbrownZ Offline
                            zbrownZ Offline
                            Na i hear he misses the LT.....
                            rx7-8.89@157mph
                            12v dodge, twins
                            • GrrG Offline
                              GrrG Offline
                              Grr
                              dont think i will ever miss a god damn lt, guess it was pretty good if you get past the electronics. I like my new setup its pretty bad ass
                              2006 Trailblazer SS- my DD
                                00Ws6TransAm
                                Explain...
                                Dont u have a turbo lt1 car now?
                                PM if you want.
                                • inspector01I Offline
                                  inspector01
                                  Tested out some new EMS yesterday, so far pretty happy with it, I think it will be nice. Also doing a bit of body work over the last couple of days, getting it ready to go for spring.
                                  PVC Squad Member #1
                                  • funky_monkey58F Offline
                                    funky_monkey58
                                    Shave and paint engine bay: Done
                                    Replace windshield...:Thought about it
                                    Repaint roof...:thought about it
                                    Build an exhaust manifold:In process
                                    Custom 74mm triple ceramic ball bearing turbo with stainless T4 housing:In process
                                    New custom intake manifold:In process
                                    Get rid of 3KGT ignitor and msd tach driver for DH61 toyota ignitor: Done
                                    Custom -10AN fuel rail: Done
                                    Custom crank trigger: Done
                                    Full 3.5" exhaust:Thought about it
                                    I think that about sums it up.
                                      00Ws6TransAm
                                      That sounds like some nice power potential?:icon_cheers:
                                      What car is this going in? Older supra?
                                        funky_monkey58
                                        Yeah it is going in my 87.
                                        Last year I took out a bearing prematurely, was running a gt4088.
                                        This next year I built an engine and switched from race fuel to E85.
                                        • Chance91C Offline
                                          Chance91C Offline
                                          Chance91
                                          Big ol snail.
