  4. The DD
The DD
26 Posts 10 Posters 5.0k Views
    JN210;318938 wrote:
    QFT!
    Youre too easy.
    • JN210J Offline
      JN210J Offline
      JN210
      DelSlow;318941 wrote:
      Youre too easy.
      I told your mother the same thing!
      *1989 Nissan 300ZX Z31 *
      > DelSlow;262050 wrote:
      > I like the new JN210
        JN210;318878 wrote:
        idk, its faster than what im use to though. Ive been driving a 98 avenger
        ...and an NA 300zx.
        • Seven1S Offline
          Seven1S Offline
          Seven1
          JN210;318880 wrote:
          ah ok, I will try to not. Ive heard the Northstars fry rings like none other
          Nope, blown head gaskets and half case seal leaks are the major downfalls of this motor. Change the coolant out if you haven't already, coolant passages were cast too close to the threads that holds the cylinder heads down, dirty coolant can cause corrosion near the threads and cause cylinder head bolts to let go. Be sure to use HDD(high Zn,Ph) oil, that generation N*'s use flat tappet cams. Beat on the motor, it's good for it, N*'s are extremely durable and respond well to an italian tune up. If a head gasket does let go check out this thread
          http://www.cadillacforums.com/forums/northstar-performance-technical-discussion/122898-northstar-headgasket-bolt-failure-please-let.html
          • zbrownZ Offline
            zbrownZ Offline
            PSiedTSi;319091 wrote:
            ...and an NA 300zx.
            Lol.....
            rx7-8.89@157mph
            12v dodge, twins
            • capitljC Offline
              capitljC Offline
              capitlj
              Those are nice cars and a 15 second quarter stock stomps what most of us dd.
              > Mitch Hedberg wrote:
              2004 Impala LS 3.8
