  4. Car Updates / Progress
  5. My project
My project
70 Posts 13 Posters 20.7k Views
  • DaveHD Offline
    DaveHD Offline
    DaveH
    The glide is lighter, good parts for it are a lot cheaper, and you have one less shift point to screw up going down the track. 😛 Overall it's a win-win.
    DaveH
    '94 Supra- 7.77 @ 176mph
    • zbrownZ Offline
      zbrownZ Offline
      the best thing i have done aside the V8 is the glide
      what does your car weigh? i am right at 3k with me in it
      atleast for me it works better on the street, it helps put the power down and manage traction
      gary rode in it on the street on the same power it was going lower 9s and can vouch for how well it hooks
      plus it loads up and gets me full boost instantly, and i can still way overpower myself on the line when on the Brake
      another thing is i have a remote fluid cooler with electric fan..... with the 350 that thing would run about all the time when driving/beating
      with the glide i think it has kicked on twice, but alot of that could do with the converter too
      rx7-8.89@157mph
      12v dodge, twins
      • legacy-user-3898L Offline
        legacy-user-3898
        I looked at my buddies glide and found out it would not work at this moment. I'm planning on running what i have for the rear suspension for now to keep the cost down 😞 But once I do like you did Zach build my 6.0 and make it more of a track car than i will go with a glide. But now i have made progress. Got the old a/c heater box out and installed the non a/c box. Got the exhaust manifold's modified today and cut the idler arm bracket out and installed a plate over the hole. Also started the hotside exhaust pipe and kinda got the downpipe figured out. Hopefully have the hotside done this week.
          legacy-user-3898
          Well made some more progress today got the hotside tack welded and figured out.
          • DaveHD Offline
            DaveHD Offline
            DaveH
            Looks good, what turbo is that?
            DaveH
              legacy-user-3898
              It's a gt-45 ( 70mm ) if i remember. It was free i'm planning on upgrading after it get this set-up done. I started looking at an S400 75mm with a T-4 flange. But i'm open to suggestion's
              • DaveHD Offline
                DaveHD Offline
                DaveH
                With a relatively big cube motor like that, I'd go with a T6. It leaves you a lot more options in the future if you decide to upgrade.
                DaveH
                • zbrownZ Offline
                  zbrownZ Offline
                  yeah if you have the room build it around a t6 footprint
                  looks good!
                  rx7-8.89@157mph
                  12v dodge, twins
                    legacy-user-3898
                    I really don't know if I will have the room for a T6 unless i cut into the fender well but then i might not have room around the hood. It's kinda tight around the turbo right now plus i will not have room for the down pipe. We were able to get 3.5 inch to fit right and i really don't want to cut into the frame that much. I even think 4 inch would be tough to do.
                      legacy-user-3898
                      well not much progress as of late. just a lot of ordering of parts. but i can say christmas is going to come early this year as everything i ordered should be here by next tuesday. then next week while i'm on vacation i will work on the fuel system and possibly pull the motor out and swap out the oil pan and weld in the drain for the turbo. i also might start some of the wiring
                        legacy-user-3898
                        Well christmas came early for me (transmission, most of my fuel system part's, starter, and misc part's i ordered). plus my buddy got his converter back and his engine for his race car. so it has been a good week for both of us 🙂
                          legacy-user-3898
                          Fuel system is almost done just have the cross over left to do. Will get that done tomorrow and then pull the motor out and swap out oil pan's and work on the oil drain for the turbo. Than after my torque converter show's up put it all back together and figure out radiator hose's and heater hose's
                            legacy-user-3898
                            Ok here is an update with some picture's. Transmisson is a th-350 with a b&m stall
                              legacy-user-3898
                              well it's been a while since an update. computer wiring done under the hood and radiator ordered and modifed
                                legacy-user-3898
                                Well it's almost done. just waiting on b.o.v. got it running last week.
                                [legacy attachment 6929]
                                  legacy-user-3898
                                  Got my b.o.v. today. But i was able to drive it before i got home and saw that it showed up. Car run's really good considering it's not tuned at all. I also have traction issue's as soon as it start's to boost the tire's break loose.
                                    legacy-user-3898
                                    I have been out driving it. Now to finish the exhaust and install the part of the cage
                                    [legacy attachment 6934]
                                    [legacy attachment 6935]
                                    • kylushK Offline
                                      kylushK Offline
                                      kylush
                                      looks sweet!
                                      1998 Z28 Camaro
                                        sounds like a fun ride. how much power you think your making?
                                        is your name doug?
                                          legacy-user-3898
                                          I really have no idea on how much power it is making yet. Only seeing about 5-6 psi right now. Yes my name is Doug
