  4. Motor choice
Motor choice
56 Posts 22 Posters 1.9k Views
  • O Offline
    O Offline
    out there
    unless i'm quite mistaken, the main reason that the b18c1 is more rev-happy, is due to it's shorter stroke (87.2mm vs 89)
    • krzydrftr93K Offline
      krzydrftr93
      so is that better then
      Matt
      92 Civic HB
      JDM d15b w/14b@8psi
        krzydrftr93
        i would like right around the 300hp range sooner or later. I dont want to have to spend a lot on tuning the thing all the time. I just want it to run good and be quick. i would be satisfied if i hit 13 with it in a year or so. summer of 06 i would prolly just do little miner mods like the intake, full exhuast, plugs, wires fuel stuff, ignition and what not.
        Matt
        92 Civic HB
        JDM d15b w/14b@8psi
        • bluejaysB Offline
          bluejaysB Offline
          bluejays
          fyi, bolt ons don't do hardly anything to any honda engines except k series
            seanjohn
            Everyone I have ever talked to who has done a b-series swap almost always says they wish they would've stay'd d-series and turboed it. Thats my opinion.
              seanjohn
                BUT... bottom line is if you want over 300whp........ you'll either need to b-series turbo, or a well built d-series.
                  seanjohn
                  I completely agree. The fact of the matter is that you can have as many d-series motors as you are willing to pick up out of people's driveways....b-series are still expensive to replace. Blow up a d-series?!?!?....who cares. In a turbo app there isn't many up's to have the b-motor.
                    agreed. however it also depends on the person, if you decide to test the limits of the stock d-series make sure that you are willing to put in the time to swap motors/trannies/clutches... if you're not willing to do that, this may not be the route for you.
                    • bluejaysB Offline
                      bluejaysB Offline
                      bluejays
                      what i was saying was, simple bolt ons ie: headers, exhaust, cai doesn't increase hp very much on any B, D, H, F series honda engine.
                      as far as going D or B if he plans on going with around 300 hp. i have this feeling its going to end up costing him more in parts and labor with a D series in the end, because 300 hp is about as much as you can push out of the D and thats built. now if you blow that up you have to buy another have it built and put in again. 300 hp out of a B series is relatively descent power for a B. your not pushing it to its limits so parts breaking isn't quite as much of a problem.
                      just out of curiosity what has tufte all replaced on his D? and what has gsr all replaced on his B?
                        ^ i think you underestimate honda motors.
                        also, bolt ons never do shit....
                          to make any power with a turbed honda u MUST sleeve the block then it wouldnt matter what motor u went with because u could push 25+ psi and if u want more just go with a bigger turbo..
                          b16-2000$
                          sleeves-1000$
                          supporting mods- lets just say 1000$
                          huge turbo-1000$
                          labor and shit- idk ask somebody that knows
                            nick made 267whp out of a stock D-series why would building it only be able to yield 300hp? Building a D-series is cheap as hell cause you can get D-series for cheap as hell...
                              b16-2000$
                              sleeves-1000$
                              huge turbo-1000$
                              untrue.... there are a plenty of guys running ridiculous hp numbers on stock sleeves now 400-500whp. go hop on honda-tech and look. they're been using forged internals, but have been keeping the stock sleeves.
                                b16-2000$
                                sleeves-1000$
                                huge turbo-1000$
                                Damn it Spoolude, we should ban you from "Car Tech"...
                                  Bryce, can you help me swap an f20c (s2000) head into my accord... 😄 :rolleyes: 😉 😛
                                    Hahaha, yeah I'm on my way! 🙂
                                      krzydrftr93
                                      im thinking the b18c1 is sounding good. Are they quick stock?
                                      Matt
                                      92 Civic HB
                                      JDM d15b w/14b@8psi
                                        170hp
                                          krzydrftr93
                                          that would move a hatch pretty good wouldnt it. I mean yait should move it a lot better then the d15 91 hp moves it. What do you think i could run in the 1/4 with the b18c1?
                                          Matt
                                          92 Civic HB
                                          JDM d15b w/14b@8psi
