  4. Turbo Testing
Turbo Testing
66 Posts 13 Posters 2.8k Views
  • 9 Offline
    9 Offline
    91psiTSI
    thats pretty pimp good luck with the rest of the testing
      vroom vroom.
        Lookin like we'll be ordering some injectors and more fuel pump cuz there's a S300 on the way and we're gonna try max that bitch out too!! SO we'll be lookin for the 650-700whp range.
        • krzydrftr93K Offline
          krzydrftr93
          Ok...Im dumb with turbo's, I will admit it. So is it bad to push a turbo to its limits like that and how do you know when its at its max??
          Matt
          92 Civic HB
          JDM d15b w/14b@8psi
            No, no harm done. Once we get the 30 psi graphs up you'll notice the airflow was maxed out based off the powerband. On the 550+ pulls power peaked @ 7000 and just held flat to 8500. Going from 30-32 psi only netted 7whp which should have been an easy 20+. This turbo is only rated @ a max of 550hp. So we met and exceeded that @ a very low boost level being these things are effiecient into the 40-50psi range.
              krzydrftr93
              Ok....Makes a little more since now...Ive been looking into turbos a little for the hatch...Not sure if I am going all motor yet or boost it...Need some money. Just getting some ideas for now to see what I am going to need/get myself into. 😄
              Matt
              92 Civic HB
              JDM d15b w/14b@8psi
                That wouldn't even be a question in my mind.
                  All motor cars are worthless. 🙂
                    krzydrftr93
                    Yea...This boost thing is winning me over right now...I would be satisfied with 250whp for a daily driven civic...I know its not a lot but I dont want to build a motor big time to take the boost...I got the new Dsport mag and they have a EG with a y8 with stock internals making 260whp...I like that idea but I would upgrade internals a little.
                    Matt
                    92 Civic HB
                    JDM d15b w/14b@8psi
                    • 9 Offline
                      9 Offline
                      91psiTSI
                      650-700 hp holy shit thats alot! you going to do that on GSR's car. im very impressed!
                        I made 262whp/214trq stock internal Z6 ran 11.9's all day.
                          krzydrftr93
                          I saw that...Didnt you run like 11.4 on slicks?? How much would that exact turbo setup cost on a y8??
                          Matt
                          92 Civic HB
                          JDM d15b w/14b@8psi
                            11.9 was my best time. PM me for details.
                              krzydrftr93
                              ^^^Your PM box is full
                              Matt
                              92 Civic HB
                              JDM d15b w/14b@8psi
                                yeah totally surprised the hell out of me...
                                • DaveHD Offline
                                  DaveHD Offline
                                  DaveH
                                  Good stuff guys, post up the dyno sheet when you can. What sort of a/f ratio where you running under boost? Did you have to change the tuning much changing to theis turbo from the PT67?
                                  DaveH
                                  '94 Supra- 7.77 @ 176mph
                                    A/F was borderline at the end. Finally ran out of injector. Otherwise we maintained right around 11.8:1 to 12.0:1. We didn't spend much time on tuning, spoolup was FAT and under boost we just tried to keep flat around the 11.8:1 area. I am sure there would be more power if we would have actually spent the time going through timing tables and so on. Just a safe generic tune on each power level.
                                    I have the runfiles but the runviewer sucks and doesn't work as well as the actual WinPEP software. Andy's printer was acting up so once he gets those mailed up we'll get them scanned and posted online.
                                    • D Offline
                                      D Offline
                                      dynotune
                                      I'll see if we can't get something up on my web today for you...
                                      andy
                                      DynoTune Speed & Performance
                                      Custom EFI Programming for Ford, GM, and all others
                                      Mobile chassis dyno service
                                      www.dynotuneusa.com
                                      (605) 753-1101
                                        Also, thanks to Andy we bring you the dyno sheets!
                                        http://www.dynotuneusa.com/turbocomparo
                                        • D Offline
                                          D Offline
                                          dynotune
                                          I guess I was a little late... 🙂
                                          www.dynotuneusa.com
                                          (605) 753-1101
