  4. Junkyard Turbo Setup
50 Posts 14 Posters 2.7k Views
  • My NOvaM Offline
    My NOvaM Offline
    My NOva
    He comes to the other side...swish
    Hey Tina come get some hamm
      seanjohn
      PSI2HI wrote:
      You have that green 4dr integra? I'd turbo way before i ever thought of supercharging, why no turbo?
      I've got a suzuka blue crx hf. The reason I'm going to supercharge is I'm running about 10.4:1 compressions plus a 100shot now. I'm gonna drop the shot to 75, and I don't want to change the bottom end setup...the most boost I will probably run is 7lbs or so, and for that amount of boost a JR is cheaper. Do you have a rom burner Nick, or editor of any sort (Hondata, AEM)?
        I'm also quite interested in this question. BTW sean we can do datalogging if you ever need to do that.
        Do you have a Wide Band Sean?
          seanjohn
          I thought about buying one with my brother, I'm actually looking into it now. But if SLS isn't too expensive I might just end up using theirs.
            Shit, i've seen you drive down Fiechtner past the shop numerous times. I think you were in GF when i was up there this past summer w/ my white Teg. IntegraGSR_98 has a editotr/romulator and i have the wideband, etc..
              seanjohn
              I was never in GF, but you've maybe seen me around town.
              I'm giving this AFC option a bit more thought, and I will look into it. HOWEVER...
              There is still a chance I'd like to stay the chipped route. In this case, I need to figure out what kind of editor to use for a pr3, then we could strap it on your wideband and create/burn maps. I wish I had some experience with map editing.
                If you want to stick with the chipped route the minimum I would recommend would be to go with an older Hondata 2b. (right around $400 for this setup) That way there will be boost tables, legit heavily used software, and I have everything necessary to tune and install it. The only thing necessary would be the use of my stage 4 system for datalogging during the initial tune.
                Otherwise I also have Uberdata laying around, (right around $25 for this setup) and although it has zero datalogging capabilities, I know tuftes wideband should be able to handle rpm to a/f ratio logging.
                  seanjohn
                  I'd rather stay away from hondata just for cost reasons, and would prefer to tune with uberdata or turbo edit witha wideband. How much for your time and a burned chip?
                    We could work something out for that. Is the ECU for the vehicle chipped already? Or does it still have to be socketed?
                      seanjohn
                      Well, I was planning on sending it away to get it socketed, but if you know how to do it, I'll give you some business. I'll need a map for my soon-to-be setup, and then we'll have to do it again in about a year when I go turbo. Let me know.
