  4. Push-button start help
45 Posts 9 Posters 3.8k Views
    if you've noticed when you turn the ignition it just supplies power to a switch.
    Get a momentary 12v dc switch, and wire it up, ghetto like the rest of the probe 😛
      Any say on the steering wheel lock? Is It something electric or mechanical?
        idk rip it all out
        • RaiderR Offline
          RaiderR Offline
          Raider
          the steering lock is mechanical...what year car do you have...I can make a key for 96 and new Fords...If you pop the ignition out then you can unlock the steering lock..or call Curt's lock n key
          POWERD BY
            well with what ever you do, good luck
              for diagrams use mitchell joel you idiot
                I want it before monday tony, YOU IDIOT. lol. I just got back from LF Ford. Had Hilgers print me one out of their book, but he gave me one for a 93 and i needed 1st gen.gahhh
                  Might just be easier to go to a junkyard and buy a new ignition cylinder that has a key already w/ it.
                  If not, it will be interesting doing the wiring. You are right, you will need a momentary pushbutton switch to attach to the starter wire(s) probably gonna be a black/yellow wire. As for the other switch you will need a toggle switch to be wired to at least 3 different relays.
                  Relay #1 will go to Ignition #1 (black/white wire) when activated
                  Relay #2 will go to Ignition #2 (black/red wire) when activated
                  Relay #3 will go to Accessory (blue wire) when activated
                  As for unlocking the steering, you might be able to just remove the stock ignition cylinder. Get a manual cuz I'm not sure how ford goes about removing them for this vehicle.
                  The downside to this is that anyone can steal your vehicle at any time if they can figure out what each switch does.
                    I realize that. This will be stored and only used at the track. I bought the car because it was cheap and I wanted to experiment on something cheap, and test myself on how much I can actually handle before taking on a more serious project. THere will be various break in the circuit for a theft deterant
                      Oh yeah, almost forgot. Trying to pull the ignition yesterday, i pulled the steering wheel, turn signal canceler ... etc. I have it all apart and access to the wires. I also have a momentary and toggle accesory switch. I am all ready, I just need the diagram and instructions on how to pull the ignition.
                        If this helps, I got my camera working, and heres a few pics of the current situation.
                        All torn apart...
                        Ignition breakdown
                        If someone wants to take a stab at naming the wires that would be awesome. CHeck, this ones all you.
                        • RaiderR Offline
                          RaiderR Offline
                          Raider
                          what year and kind of car...I will look for a manual in the shop for ya
                          POWERD BY
                          • RaiderR Offline
                            RaiderR Offline
                            Raider
                            if its a 90-91 probe you have to drop the steering column down( remove 4 bolts) and there are 2 break away screws..the heads of the screws break off when u install the ignition cylinder...take a cut off wheel and cut a slot into each screw and use a screw driver to remove the screws...I will post a pic of the breakdown of the steering column
                            POWERD BY
                            • RaiderR Offline
                              RaiderR Offline
                              Raider
                              if you need anymore help drop me a PM
                              POWERD BY
                                hELL yeah dude thanks a bunch!!!!!
                                • RaiderR Offline
                                  RaiderR Offline
                                  Raider
                                  np man...I am a Parts God 😄
                                  POWERD BY
                                    ihey doo those pics help?
                                    • RaiderR Offline
                                      RaiderR Offline
                                      Raider
                                      oh and after you remove the ign cylinder you can remove the ign switch from it and start it manually
                                      POWERD BY
                                        here ill go get a quick pic of theose bolts i think your talking about... tell me if i am right
                                          is this what you were talking about?
