  4. Push-button start help
45 Posts 9 Posters 3.2k Views
    Any say on the steering wheel lock? Is It something electric or mechanical?
      idk rip it all out
      • RaiderR Offline
        RaiderR Offline
        Raider
        the steering lock is mechanical...what year car do you have...I can make a key for 96 and new Fords...If you pop the ignition out then you can unlock the steering lock..or call Curt's lock n key
        POWERD BY
          well with what ever you do, good luck
            for diagrams use mitchell joel you idiot
              I want it before monday tony, YOU IDIOT. lol. I just got back from LF Ford. Had Hilgers print me one out of their book, but he gave me one for a 93 and i needed 1st gen.gahhh
                Might just be easier to go to a junkyard and buy a new ignition cylinder that has a key already w/ it.
                If not, it will be interesting doing the wiring. You are right, you will need a momentary pushbutton switch to attach to the starter wire(s) probably gonna be a black/yellow wire. As for the other switch you will need a toggle switch to be wired to at least 3 different relays.
                Relay #1 will go to Ignition #1 (black/white wire) when activated
                Relay #2 will go to Ignition #2 (black/red wire) when activated
                Relay #3 will go to Accessory (blue wire) when activated
                As for unlocking the steering, you might be able to just remove the stock ignition cylinder. Get a manual cuz I'm not sure how ford goes about removing them for this vehicle.
                The downside to this is that anyone can steal your vehicle at any time if they can figure out what each switch does.
                  I realize that. This will be stored and only used at the track. I bought the car because it was cheap and I wanted to experiment on something cheap, and test myself on how much I can actually handle before taking on a more serious project. THere will be various break in the circuit for a theft deterant
                    Oh yeah, almost forgot. Trying to pull the ignition yesterday, i pulled the steering wheel, turn signal canceler ... etc. I have it all apart and access to the wires. I also have a momentary and toggle accesory switch. I am all ready, I just need the diagram and instructions on how to pull the ignition.
                      If this helps, I got my camera working, and heres a few pics of the current situation.
                      All torn apart...
                      Ignition breakdown
                      If someone wants to take a stab at naming the wires that would be awesome. CHeck, this ones all you.
                      • RaiderR Offline
                        RaiderR Offline
                        Raider
                        what year and kind of car...I will look for a manual in the shop for ya
                        POWERD BY
                        • RaiderR Offline
                          RaiderR Offline
                          Raider
                          if its a 90-91 probe you have to drop the steering column down( remove 4 bolts) and there are 2 break away screws..the heads of the screws break off when u install the ignition cylinder...take a cut off wheel and cut a slot into each screw and use a screw driver to remove the screws...I will post a pic of the breakdown of the steering column
                          POWERD BY
                          • RaiderR Offline
                            RaiderR Offline
                            Raider
                            if you need anymore help drop me a PM
                            POWERD BY
                              hELL yeah dude thanks a bunch!!!!!
                              • RaiderR Offline
                                RaiderR Offline
                                Raider
                                np man...I am a Parts God 😄
                                POWERD BY
                                  ihey doo those pics help?
                                  • RaiderR Offline
                                    RaiderR Offline
                                    Raider
                                    oh and after you remove the ign cylinder you can remove the ign switch from it and start it manually
                                    POWERD BY
                                      here ill go get a quick pic of theose bolts i think your talking about... tell me if i am right
                                        is this what you were talking about?
                                        • RaiderR Offline
                                          RaiderR Offline
                                          Raider
                                          is that a pic from the top? if it is then those are the 2 that u have to remove...I sent you a pm
                                          POWERD BY
