  4. Reading plugs
Reading plugs
21 Posts 8 Posters 1.2k Views
    What causes the spark plug to look like this? This is out of one of our work trucks. The other 3 plugs look fine.
      Ash deposits or coolant deposits. Any cel's?
        No, the CEL is not on. I'll scan it tomorrow though.
          im betting its eating oil in that cylinder...
          edit...
          or it looks like it could be overheating.
          or it could be a dodge?
            Time to buy a leakdown tester then. I'll post up the compression numbers tomorrow when I get back to the office but they all looked pretty good.
              any additives in the oil or fuel?
              bad valve seals?
                reading sparkplug charts i see...
                  Maybe....
                    Here are the compression test results.
                    Cyl Dry Wet
                    1 160 160
                    2 153 162
                    3 155 162
                    4 165 170
                    • D Offline
                      D Offline
                      dynotune
                      is it a 318/360 with a cracked head (between the valves)??? They leak coolant when running but won't show up on a compression test...
                      DynoTune Speed & Performance
                      Mobile chassis dyno service
                      www.dynotuneusa.com
                      (605) 753-1101
                        It is actually a 2.5 I4 pushrod AMC motor out of a 98 Dakota. The motor is a reman that was installed in the spring.
                        • D Offline
                          D Offline
                          dynotune
                          i'd say you're probably still gonna need to jerk the head and investigate...
                          www.dynotuneusa.com
                          (605) 753-1101
                            I tore it down and should have the head off after lunch here.
                            • ruthless351R Offline
                              ruthless351
                              You have way too much time on your hands!! O BTW Im gunna put money on coolant.
                                Here is what I found.
                                  Have the head pressure tested yet?
                                    Nope. The head doesn't look cracked or anything. A couple of guys on TCS were suggesting that the cylinder was lean. I pulled the head off since it seemed to be using some coolant and leaking out of the radiator cap even though the cap is fine. I've got the parts for it and it should be back together tomorrow morning.
                                      Too me that def doesn't look like a lean condition, i'd say coolant is the culprit hands down
                                        I'd definately get it magnufluxed/pressure tested to verify there isnt any cracks hiding there. and def get it resurfaced.
                                          i blame obama
