  4. Reading plugs
Reading plugs
21 Posts 8 Posters 1.8k Views
  • D
    D
    dynotune
    is it a 318/360 with a cracked head (between the valves)??? They leak coolant when running but won't show up on a compression test...
    DynoTune Speed & Performance
    Mobile chassis dyno service
    www.dynotuneusa.com
    (605) 753-1101
    • MisterCMKM
      MisterCMKM
      It is actually a 2.5 I4 pushrod AMC motor out of a 98 Dakota. The motor is a reman that was installed in the spring.
      thrash;315544 wrote:
      Ford is back :)
      • D
        D
        dynotune
        i'd say you're probably still gonna need to jerk the head and investigate...
        www.dynotuneusa.com
        (605) 753-1101
        • MisterCMKM
          MisterCMKM
          I tore it down and should have the head off after lunch here.
          Ford is back :)
          • ruthless351R
            ruthless351R
            ruthless351
            You have way too much time on your hands!! O BTW Im gunna put money on coolant.
            • MisterCMKM
              MisterCMKM
              Here is what I found.
              Ford is back :)
              • wesholeW
                wesholeW
                Have the head pressure tested yet?
                • MisterCMKM
                  MisterCMKM
                  Nope. The head doesn't look cracked or anything. A couple of guys on TCS were suggesting that the cylinder was lean. I pulled the head off since it seemed to be using some coolant and leaking out of the radiator cap even though the cap is fine. I've got the parts for it and it should be back together tomorrow morning.
                  Ford is back :)
                  • zbrownZ
                    zbrownZ
                    Too me that def doesn't look like a lean condition, i'd say coolant is the culprit hands down
                    • wesholeW
                      wesholeW
                      I'd definately get it magnufluxed/pressure tested to verify there isnt any cracks hiding there. and def get it resurfaced.
                      • ParkerP
                        ParkerP
                        i blame obama
                        BlueSRT0483;244555 wrote:
                        Trafik Jamz;260984 wrote:
                        You are right Parker.
