  4. Reading plugs
Reading plugs
21 Posts 8 Posters 1.8k Views
  • MisterCMKM
    MisterCMKM
    Here are the compression test results.
    Cyl Dry Wet
    1 160 160
    2 153 162
    3 155 162
    4 165 170
    thrash;315544 wrote:
    Ford is back :)
    • D
      D
      dynotune
      is it a 318/360 with a cracked head (between the valves)??? They leak coolant when running but won't show up on a compression test...
      DynoTune Speed & Performance
      Mobile chassis dyno service
      www.dynotuneusa.com
      (605) 753-1101
      • MisterCMKM
        MisterCMKM
        It is actually a 2.5 I4 pushrod AMC motor out of a 98 Dakota. The motor is a reman that was installed in the spring.
        Ford is back :)
        • D
          D
          dynotune
          i'd say you're probably still gonna need to jerk the head and investigate...
          www.dynotuneusa.com
          (605) 753-1101
          • MisterCMKM
            MisterCMKM
            I tore it down and should have the head off after lunch here.
            Ford is back :)
            • ruthless351R
              ruthless351R
              ruthless351
              You have way too much time on your hands!! O BTW Im gunna put money on coolant.
              • MisterCMKM
                MisterCMKM
                Here is what I found.
                Ford is back :)
                • wesholeW
                  wesholeW
                  Have the head pressure tested yet?
                  • MisterCMKM
                    MisterCMKM
                    Nope. The head doesn't look cracked or anything. A couple of guys on TCS were suggesting that the cylinder was lean. I pulled the head off since it seemed to be using some coolant and leaking out of the radiator cap even though the cap is fine. I've got the parts for it and it should be back together tomorrow morning.
                    Ford is back :)
                    • zbrownZ
                      zbrownZ
                      Too me that def doesn't look like a lean condition, i'd say coolant is the culprit hands down
                      • wesholeW
                        wesholeW
                        I'd definately get it magnufluxed/pressure tested to verify there isnt any cracks hiding there. and def get it resurfaced.
                        • ParkerP
                          ParkerP
                          i blame obama
                          BlueSRT0483;244555 wrote:
                          Trafik Jamz;260984 wrote:
                          You are right Parker.
