  4. Car Updates / Progress
  5. New project
New project
336 Posts 43 Posters 54.7k Views
  • JoelJ
    JoelJ
    so the lights work, does that mean its "street Legal"?
    • XJHEADX
      XJHEADX
      FUCKING RIGHT IT IS STREET LEGAL.
      It is about the same as my Cobra minus the rear seat delete and cell in the trunk.
      • JoelJ
        JoelJ
        :eek:so u plan on running around 1000hp or so, chute packed down thirteenth?
        • XJHEADX
          XJHEADX
          Why not. I did it with the cobra all the time. Well somtimes I pulled the chute off.
          PS. I can detune to about 750-800 for the street.
          • JoelJ
            JoelJ
            lawl at 750 hp being "detuned". Keep the parachute for added effect.
            So the questions now is, wheres the original number matching engine for the vert?
            • XJHEADX
              XJHEADX
              Thinking about it 750-800 might be a tad too much for a lighter car. I can always put smaller wastegate springs in it. The AMS-1000 doesn't care about spring size. It adds boost until your set value is met regardless of spring size.
              I still have the motor. Just needs some pistons. It's a Ford, checking Ford part markings to insure that the parts are original is not possible. GM used matching serial numbers. The Ford only uses casting numbers with dates. At least that is what I am led to believe.
              • 63vette6
                63vette6
                63vette
                What was its race weight?
                • DaveHD
                  DaveHD
                  Car looks good all cleaned up. I spose you got the motor swap about done?
                  • z31Z
                    z31Z
                    z31
                    Sharp looking car. :icon_cheers:
                    What is the gauge in the rear bumper for? :icon_scratch:
                    • XJHEADX
                      XJHEADX
                      Yep, all ready to go. Just went for a cruise. She gets to 180 real quick
                      Voltage gauge. Quick connects right below it.
                      • MisterCMKM
                        MisterCMKM
                        You gotta get those ghey as aids taillights off of the car and put the stock horizontal ones back on.
                        thrash;315544 wrote:
                        Ford is back :)
                        • capitljC
                          capitljC
                          capitlj
                          Awesome!!!!!
                          Mitch Hedberg wrote:
                          2004 Impala LS 3.8
                          • z31Z
                            z31Z
                            z31
                            Here it is. :icon_geek:
                            • 63vette6
                              63vette6
                              63vette
                              t.
                              with or without the blades engaged?
                              sorry...but you had to see it coming....
                              KUBOTA ORANGE BABY!!!!
                              • XJHEADX
                                XJHEADX
                                That was without, only 165 engaged.
                                Anyways, got a little done. Glad I didn't open any beers while you guys were here, never would have gotten anything done.
                                Cobra bay
                                • zbrownZ
                                  zbrownZ
                                  how did everything look in the motor?? better or worse than you expected??
                                  • 63vette6
                                    63vette6
                                    63vette
                                    Wow, you did get a lot done!
                                    • XJHEADX
                                      XJHEADX
                                      Only thing I thought was odd was the intake runners in the head had some tar-like sludge on the bottom of them. I think it may be too rich at part throttle cruising. It always felt like it wanted to stumble when cruising around. Besides that everything else looks good. I thought it would be a little cleaner on the valves. But not bad for what it has been through. 150+ dyno pulls, 40 or so passes last year and who knows how miles Andy put on it while it was down in SD. I always wondered why the back seat stunk.
                                      • 63vette6
                                        63vette6
                                        63vette
                                        valve timing was off a hair.
                                        • 63vette6
                                          63vette6
                                          63vette
                                          no avatar wtf???
                                          ahhhhhh thats better.. 🙂
