  4. Car Updates / Progress
  5. New project
New project
336 Posts 43 Posters 54.7k Views
  • JoelJ
    JoelJ
    XJHEAD;260506 wrote:
    Why not. I did it with the cobra all the time. Well somtimes I pulled the chute off.
    PS. I can detune to about 750-800 for the street.
    lawl at 750 hp being "detuned". Keep the parachute for added effect.
    So the questions now is, wheres the original number matching engine for the vert?
    • XJHEADX
      XJHEADX
      Thinking about it 750-800 might be a tad too much for a lighter car. I can always put smaller wastegate springs in it. The AMS-1000 doesn't care about spring size. It adds boost until your set value is met regardless of spring size.
      I still have the motor. Just needs some pistons. It's a Ford, checking Ford part markings to insure that the parts are original is not possible. GM used matching serial numbers. The Ford only uses casting numbers with dates. At least that is what I am led to believe.
      • 63vette6
        63vette6
        63vette
        What was its race weight?
        • DaveHD
          DaveHD
          Car looks good all cleaned up. I spose you got the motor swap about done?
          • z31Z
            z31Z
            z31
            Sharp looking car. :icon_cheers:
            What is the gauge in the rear bumper for? :icon_scratch:
            • XJHEADX
              XJHEADX
              Yep, all ready to go. Just went for a cruise. She gets to 180 real quick
              Voltage gauge. Quick connects right below it.
              • MisterCMKM
                MisterCMKM
                You gotta get those ghey as aids taillights off of the car and put the stock horizontal ones back on.
                thrash;315544 wrote:
                Ford is back :)
                • capitljC
                  capitljC
                  capitlj
                  Awesome!!!!!
                  Mitch Hedberg wrote:
                  2004 Impala LS 3.8
                  • z31Z
                    z31Z
                    z31
                    Here it is. :icon_geek:
                    • 63vette6
                      63vette6
                      63vette
                      t.
                      with or without the blades engaged?
                      sorry...but you had to see it coming....
                      KUBOTA ORANGE BABY!!!!
                      • XJHEADX
                        XJHEADX
                        That was without, only 165 engaged.
                        Anyways, got a little done. Glad I didn't open any beers while you guys were here, never would have gotten anything done.
                        Cobra bay
                        • zbrownZ
                          zbrownZ
                          how did everything look in the motor?? better or worse than you expected??
                          • 63vette6
                            63vette6
                            63vette
                            Wow, you did get a lot done!
                            • XJHEADX
                              XJHEADX
                              Only thing I thought was odd was the intake runners in the head had some tar-like sludge on the bottom of them. I think it may be too rich at part throttle cruising. It always felt like it wanted to stumble when cruising around. Besides that everything else looks good. I thought it would be a little cleaner on the valves. But not bad for what it has been through. 150+ dyno pulls, 40 or so passes last year and who knows how miles Andy put on it while it was down in SD. I always wondered why the back seat stunk.
                              • 63vette6
                                63vette6
                                63vette
                                valve timing was off a hair.
                                • 63vette6
                                  63vette6
                                  63vette
                                  no avatar wtf???
                                  ahhhhhh thats better.. 🙂
                                  • DaveHD
                                    DaveHD
                                    XJHEAD;260630 wrote:
                                    Only thing I thought was odd was the intake runners in the head had some tar-like sludge on the bottom of them. I think it may be too rich at part throttle cruising. It always felt like it wanted to stumble when cruising around. Besides that everything else looks good. I thought it would be a little cleaner on the valves. But not bad for what it has been through. 150+ dyno pulls, 40 or so passes last year and who knows how miles Andy put on it while it was down in SD. I always wondered why the back seat stunk.legacy image
                                    E98 will clean those valves right up. Mine looked cleaner after running all season than they did when I put them in.
                                    • z31Z
                                      z31Z
                                      z31
                                      Here is the before picture. :icon_bigsmurf:
                                      • XJHEADX
                                        XJHEADX
                                        Took about 40+ lbs out last night and today. Everything else is pretty much stripped already.
                                        • XJHEADX
                                          XJHEADX
                                          Just weighed the car;
                                          No engine
                                          No Tranny
                                          No Fuel
                                          No turbo/exhaust
                                          2025 lbs. should be right around 3100 lbs. when back together.
