  4. Car Updates / Progress
  5. Update on the stang
Update on the stang
29 Posts 14 Posters 6.6k Views
  • ruthless351R Offline
    ruthless351
    Picked these up from the cities last weekend for a steal! 🙂 They are the GT40heads that came on the 93 cobra mustang and some explorers. Just got them back from the machine shop today and got the green light to start building them.
    As soon as i get my package from Summit i will be doing electric fans and an A/C delete. So muck work to do! Should be enough to get the pony going a little quicker. :icon_salut:
      keep the a/c...
      • XJHEADX Offline
        XJHEADX Offline
        Good deal. What cam do you have in there?
          ruthless351
          Parker;267120 wrote:
          keep the a/c...
          It is leaking at the rear of the compressor. Tired of fixing it, besides i never use it. I will be saving the parts if i ever want to put it back on.
          I have The E-303 cam.
          Duration 282/282, Lift .498/.498
            Looks good man, hopefully a new personal best this year!
            • RaiderR Offline
              RaiderR Offline
              Raider
              Shawn to bad the turtle can still beat it
              POWERD BY
              • XJHEADX Offline
                XJHEADX Offline
                I think I have a F cam if you want to swap. I'll have to double check specs, it could be a B-cam I just don't remember.
                E-Cam
                .000 282° 282° .498
                .050 220° 220° .498
                F-Cam
                .000 286 286 .512
                .050 226 226 .512
                • MattM Offline
                  MattM Offline
                  Matt
                  Looks way cleaner without it also.
                    ruthless351
                    I agree with clean up without the A/C! Thanks for the idea in my head bill!
                    • ChristianC Offline
                      ChristianC Offline
                      Christian
                      Keep the a/c! I took mine out and hate it. Keep the a/c!
                      Playtime Performance
                      06 F-150 Lariat
                      • XJHEADX Offline
                        XJHEADX Offline
                        Take the A/C out and put the top down. Oops never mind.
                        I have a 272 @ .050 with .714 lift you can try too...
                          Thats more like it....
                            ruthless351
                            I bet!
                              ruthless351
                              I also just finished my 3g conversion tonight. Its a upgrade from the standard 2g (75 amp) alternator to the 3g (130 amp). Now i have enough juice to power that electric cooling fan, stereo, and high volume fuel pump!
                              From this......75amp
                              To this...130 amp
                              • capitljC Offline
                                capitljC Offline
                                capitlj
                                The 3G alts look soooo much better.
                                > Mitch Hedberg wrote:
                                2004 Impala LS 3.8
                                  ChristianC Offline
                                  Christian
                                  I put a 3g on my vert a couple years ago they still don't charge well at a idle.
                                  06 F-150 Lariat
                                    ruthless351
                                    Did you swap the pulley from the 2g to the 3g? That is supposed to help the charge at idle issue. I will have to see what mine does after everything is done. Last night it was charging at around 14.3-14.8. As for amps i dont know yet.
                                      ChristianC Offline
                                      Christian
                                      Don't remember but I think I have a couple laying around and I'll have to try that. Thanks.
                                      06 F-150 Lariat
                                        ruthless351
                                        Started on the head swap tonight, but had to stop cuz i left my AC disconnect tools at work.
                                        • C Offline
                                          C Offline
                                          Chirp5957
                                          gt40 heads = Thumbs up! mpg down lol
                                          1996 cobra 13.20 @106
                                          4.10 gears
                                          short throw shift
                                          off road x pipe
                                          BBK Cold Air
                                          Diablo chip
                                          BBK LT
