  4. Car Updates / Progress
  5. Update on the stang
Update on the stang
29 Posts 14 Posters 7.0k Views
  • XJHEADX
    XJHEADX
    Good deal. What cam do you have in there?
    • ruthless351R
      ruthless351R
      ruthless351
      Parker;267120 wrote:
      keep the a/c...
      It is leaking at the rear of the compressor. Tired of fixing it, besides i never use it. I will be saving the parts if i ever want to put it back on.
      I have The E-303 cam.
      Duration 282/282, Lift .498/.498
      • SPANISH-RICES
        SPANISH-RICES
        Looks good man, hopefully a new personal best this year!
        • RaiderR
          RaiderR
          Raider
          Shawn to bad the turtle can still beat it
          POWERD BY
          • XJHEADX
            XJHEADX
            I think I have a F cam if you want to swap. I'll have to double check specs, it could be a B-cam I just don't remember.
            E-Cam
            .000 282° 282° .498
            .050 220° 220° .498
            F-Cam
            .000 286 286 .512
            .050 226 226 .512
            • MattM
              MattM
              Matt
              Looks way cleaner without it also.
              • ruthless351R
                ruthless351R
                ruthless351
                I agree with clean up without the A/C! Thanks for the idea in my head bill!
                • ChristianC
                  ChristianC
                  Christian
                  Keep the a/c! I took mine out and hate it. Keep the a/c!
                  Playtime Performance
                  06 F-150 Lariat
                  • XJHEADX
                    XJHEADX
                    Take the A/C out and put the top down. Oops never mind.
                    I have a 272 @ .050 with .714 lift you can try too...
                    • zbrownZ
                      zbrownZ
                      Thats more like it....
                      • ruthless351R
                        ruthless351R
                        ruthless351
                        I bet!
                        • ruthless351R
                          ruthless351R
                          ruthless351
                          I also just finished my 3g conversion tonight. Its a upgrade from the standard 2g (75 amp) alternator to the 3g (130 amp). Now i have enough juice to power that electric cooling fan, stereo, and high volume fuel pump!
                          From this......75amp
                          To this...130 amp
                          • capitljC
                            capitljC
                            capitlj
                            The 3G alts look soooo much better.
                            Mitch Hedberg wrote:
                            2004 Impala LS 3.8
                            • ChristianC
                              ChristianC
                              Christian
                              I put a 3g on my vert a couple years ago they still don't charge well at a idle.
                              06 F-150 Lariat
                              • ruthless351R
                                ruthless351R
                                ruthless351
                                Did you swap the pulley from the 2g to the 3g? That is supposed to help the charge at idle issue. I will have to see what mine does after everything is done. Last night it was charging at around 14.3-14.8. As for amps i dont know yet.
                                • ChristianC
                                  ChristianC
                                  Christian
                                  Don't remember but I think I have a couple laying around and I'll have to try that. Thanks.
                                  06 F-150 Lariat
                                  • ruthless351R
                                    ruthless351R
                                    ruthless351
                                    Started on the head swap tonight, but had to stop cuz i left my AC disconnect tools at work.
                                    • C
                                      C
                                      Chirp5957
                                      gt40 heads = Thumbs up! mpg down lol
                                      1996 cobra 13.20 @106
                                      4.10 gears
                                      short throw shift
                                      off road x pipe
                                      BBK Cold Air
                                      Diablo chip
                                      BBK LT
                                      • MisterCMKM
                                        MisterCMKM
                                        Still weaksauce
                                        Should gone with the trickflow heads
                                        thrash;315544 wrote:
                                        Ford is back :)
                                        • GrrG
                                          GrrG
                                          word, still not gonna make much power, an improvement none the less though
