  4. Z31 Introduction
Z31 Introduction
107 Posts 22 Posters 16.1k Views
  • z31Z
    z31Z
    z31
    Thanx guys :icon_bigsmurf:
    • Cura86C
      Cura86C
      Cura86
      The mods for the winter...have you done all that? If so I HAVE to come over and check that out!
      www.RoadsideSalvage.com
      • JN210J
        JN210J
        JN210
        Jason you've been on here how long?...welcome anyway haha.
        *1989 Nissan 300ZX Z31 *
        DelSlow;262050 wrote:
        I like the new JN210
        • z31Z
          z31Z
          z31
          Mods this winter:
          Installed~ Nistune engine management
          Installed~ 560cc DSM fuel injectors
          Half done~ gutted intake plenum" or "Engloid style" (upper intake plenum)
          Done~ Replace 7.8:i pistons with 9:1 pistons
          Done~ Port the cylinder heads
          Done~ Port the Lower intake plenum
          Installed~ Certified Muffler 3inch Mandrel bent exhaust
          On the shelf~ Front mount intercooler with 2 1/2 inch piping
          On the shelf~ HKS Blow off valve
          Installed~ Flex-a-lite dual electric cooling fans
          On the shelf~polyurethane sub frame mounts in rear sub frame
          On the shelf~ Rear camber Mod
          On the shelf~ Turbo CV shafts and stub axles (stronger than N/A)
          On the shelf~ ZR racing front coil springs (325lb/in)
          On the shelf~ Front mount intercooler with 2 1/2 piping
          Loteck 3 gauge pod
          Autometer temp gage
          Autometer oil pressure gauge
          Maxima 90 amp alternator mod
          Aeromotive Fuel pressure regulator
          H4 headlight harness with relays
          :icon_bigsmurf:
          • D S ohMD
            D S ohMD
            D S ohM
            Welcome to the site. I believe we've met...haha.
            I wanna go fast!
            • z31Z
              z31Z
              z31
              Well, if you look up in the upper right corner you can see. :icon_bigsmurf: ^^^^
              • z31Z
                z31Z
                z31
                I installed my 3 inch mandrel bent exhaust. Sounds nice. :icon_cheers:
                • z31Z
                  z31Z
                  z31
                  This is the difference between the stock down pipe VS the CM 3 inch in the area that goes under the transmission cross member. :icon_geek:
                  • z31Z
                    z31Z
                    z31
                    9:1 Pistons and rods in assembled short block.
                    • GrrG
                      GrrG
                      bout time you get something done
                      • zbrownZ
                        zbrownZ
                        So why didn't you stick good rods and pistons in? or are stock pistons forged?
                        • zbrownZ
                          zbrownZ
                          $500 forged pistons >>> $500 exhaust
                          • z31Z
                            z31Z
                            z31
                            $575 Exhaust as A mater of fact. :icon_bigsmurf:
                            • z31Z
                              z31Z
                              z31
                              The stock NA internals have been run at 500 WHP by quite a few people.
                              • zbrownZ
                                zbrownZ
                                then why does it seem like there is a rotary engine under your hood??
                                • z31Z
                                  z31Z
                                  z31
                                  Explain? :icon_scratch:
                                  • GrrG
                                    GrrG
                                    it comes out at least once a year to be rebuilt, much like a rotary
                                    • 24valvenotak2
                                      24valvenotak2
                                      it might not be fast and it might not handle that well but it aint a pimp whip if the lights dont flip.
                                      63vette;288530 wrote:
                                      • z31Z
                                        z31Z
                                        z31
                                        What are you talking about? I haven't rebuilt any motors VG30 motors, and the one I'm currently working on is only half done. So does that count as .5 VG30 motors? :icon_scratch:
                                        • fdfreakF
                                          fdfreakF
                                          fdfreak
                                          how is it going Jason? welcome? i dont know im confused. too many people introducing themselves after they have been on here for 2+years. I might just have to introduce myself again just to start a new thread.
                                          anyway, hope to see you out a little more this summer. you and Gary both. Maybe I go to the wrong events.
                                          12.645@118mph 12.6psi
