Z31 Introduction
Cura86;269089 wrote:
The mods for the winter...have you done all that? If so I HAVE to come over and check that out!Mods this winter:
Installed~ Nistune engine management
Installed~ 560cc DSM fuel injectors
Half done~ gutted intake plenum" or "Engloid style" (upper intake plenum)
Done~ Replace 7.8:i pistons with 9:1 pistons
Done~ Port the cylinder heads
Done~ Port the Lower intake plenum
Installed~ Certified Muffler 3inch Mandrel bent exhaust
On the shelf~ Front mount intercooler with 2 1/2 inch piping
On the shelf~ HKS Blow off valve
Installed~ Flex-a-lite dual electric cooling fans
On the shelf~polyurethane sub frame mounts in rear sub frame
On the shelf~ Rear camber Mod
On the shelf~ Turbo CV shafts and stub axles (stronger than N/A)
On the shelf~ ZR racing front coil springs (325lb/in)
On the shelf~ Front mount intercooler with 2 1/2 pipingLoteck 3 gauge pod
Autometer temp gage
Autometer oil pressure gauge
Maxima 90 amp alternator mod
Aeromotive Fuel pressure regulator
H4 headlight harness with relays:icon_bigsmurf:
