  4. Z31 Introduction
Z31 Introduction
107 Posts 22 Posters 14.1k Views
  • z31Z Offline
    z31Z Offline
    z31
    Hello, My name is Jason, I'm from Breckenridge Minnesota and my car is a 1986 Nissan 300ZX.
    Engine:
    Cone air filter
    Z32 air flow meter
    Custom turbo intake pipe
    Precision PTE#44 Turbo in bored stock exhaust housing
    CXRacing Front Mount intercooler with 2.5 in pipe
    HKS SSQV Super Sequential Turbo Blow Off Valve
    60 MM Nissan Sentra throttle body
    Acadiana Sports Car Orphanage Gutted upper Intake Manifold plenum with emissions delete
    Ported & Polished lower intake manifold
    Ported & Polished cylinder heads
    Schnider Racing Cams
    Precision 880cc fuel injectors
    bullit aluminum fuel rails
    Walbro 255 in tank fuel pump
    Aeromotive fuel pressure regulator
    Front mount engine oil cooler
    Polyurethane Engine mounts
    Exhaust
    Ported stock exhaust manifolds
    Ported stock turbo turbine housing (T3)
    Ported internal wastegate
    Ported turbo exhaust outlet elbow
    Certified Muffler 3 inch exhaust (cat delete with Magnaflow muffler)
    Drive train:
    South Bend DXD stage 6 clutch
    Fidanza Aluminum Flywheel
    Nissan 30a 5-speed trans
    Custom heavy duty 3in diameter steel drive shaft
    Welded 3:54 rear differential
    solid differential mount
    88 turbo subframe poly mounted
    Chassis & Electrical:
    Flexolite dual electric fans
    Maxima 90 amp alternator mod
    H4 Headlight conversion 100/130 watt bulbs
    Autometer boost gauge
    Innovate motor sports LM1 wide band
    Nistune engine tuning software
    MBC 2 stage boost controller (Boost Valve.com)
    ZR racing front coil springs (300lb/in)
    ZR racing rear coil springs (325lb/in)
    Axis Metal Master Brake pads
    Goodridge stainless steel brake lines
    Z Racing 6 spoke chrome aluminum rims
    Front tires.... 225/50/16
    Rear tires....Nitto DR's 245/50/16
    My track times at Interstate dragways, Sabin MN Sunday August 8:
    My two best runs on 10lbs boost was
    [email protected].... 2.02 60ft
    [email protected].... 1.99 60ft
    My 4 best runs on 12-13lbs boost was
    [email protected] 60ft
    My best run at 15lbs boost was
    12-13 lbs boost
    http://www.youtube.com/watch?v=JF76ETa951Y
    http://www.youtube.com/watch?v=DCWa6BlQKQ0
    15 lbs boost
    http://www.youtube.com/watch?v=B0f4jqPBE20
    Race weight was 3500lbs 58mm turbo, drag radials on E85.
    Ported and polished heads with 270H cams 3in exhaust.
      shits weak sauce, gonna need more than that
      • SlowicaS Offline
        SlowicaS Offline
        Slowica
        welcome, nice 300
        • z31Z Offline
          z31Z Offline
          z31
          Slowica;269044 wrote:
          welcome, nice 300
          Thank you!
            welcome
            • NikkiaN Offline
              NikkiaN Offline
              Nikkia
              I've always like those model Z's Great Ride!
              1987 Chevy Celebrity Beater "Sullyie"
              1994 Toyota Supra Twin Turbo
              1963 Oldsmobile Super 88 "Abigail"
              2006 Toyota 4Runner "Virginia"
                Welcome. I am a fan of those older style Nissans.
                • z31Z Offline
                  z31Z Offline
                  z31
                  Thanx guys :icon_bigsmurf:
                  • Cura86C Offline
                    Cura86C Offline
                    Cura86
                    The mods for the winter...have you done all that? If so I HAVE to come over and check that out!
                    www.RoadsideSalvage.com
                    • JN210J Offline
                      JN210J Offline
                      JN210
                      Jason you've been on here how long?...welcome anyway haha.
                      *1989 Nissan 300ZX Z31 *
                      > DelSlow;262050 wrote:
                      > I like the new JN210
                      • z31Z Offline
                        z31Z Offline
                        z31
                        Mods this winter:
                        Installed~ Nistune engine management
                        Installed~ 560cc DSM fuel injectors
                        Half done~ gutted intake plenum" or "Engloid style" (upper intake plenum)
                        Done~ Replace 7.8:i pistons with 9:1 pistons
                        Done~ Port the cylinder heads
                        Done~ Port the Lower intake plenum
                        Installed~ Certified Muffler 3inch Mandrel bent exhaust
                        On the shelf~ Front mount intercooler with 2 1/2 inch piping
                        On the shelf~ HKS Blow off valve
                        Installed~ Flex-a-lite dual electric cooling fans
                        On the shelf~polyurethane sub frame mounts in rear sub frame
                        On the shelf~ Rear camber Mod
                        On the shelf~ Turbo CV shafts and stub axles (stronger than N/A)
                        On the shelf~ ZR racing front coil springs (325lb/in)
                        On the shelf~ Front mount intercooler with 2 1/2 piping
                        Loteck 3 gauge pod
                        Autometer temp gage
                        Autometer oil pressure gauge
                        Aeromotive Fuel pressure regulator
                        H4 headlight harness with relays
                        :icon_bigsmurf:
                        • D S ohMD Offline
                          D S ohMD Offline
                          D S ohM
                          Welcome to the site. I believe we've met...haha.
                          I wanna go fast!
                          • z31Z Offline
                            z31Z Offline
                            z31
                            Well, if you look up in the upper right corner you can see. :icon_bigsmurf: ^^^^
                            • z31Z Offline
                              z31Z Offline
                              z31
                              I installed my 3 inch mandrel bent exhaust. Sounds nice. :icon_cheers:
                              • z31Z Offline
                                z31Z Offline
                                z31
                                This is the difference between the stock down pipe VS the CM 3 inch in the area that goes under the transmission cross member. :icon_geek:
                                • z31Z Offline
                                  z31Z Offline
                                  z31
                                  9:1 Pistons and rods in assembled short block.
                                    bout time you get something done
                                      So why didn't you stick good rods and pistons in? or are stock pistons forged?
                                        $500 forged pistons >>> $500 exhaust
                                        • z31Z Offline
                                          z31Z Offline
                                          z31
                                          $575 Exhaust as A mater of fact. :icon_bigsmurf:
