Z31 Introduction
Hello, My name is Jason, I'm from Breckenridge Minnesota and my car is a 1986 Nissan 300ZX.
Engine:
Cone air filter
Z32 air flow meter
Custom turbo intake pipe
Precision PTE#44 Turbo in bored stock exhaust housing
CXRacing Front Mount intercooler with 2.5 in pipe
HKS SSQV Super Sequential Turbo Blow Off Valve
60 MM Nissan Sentra throttle body
Acadiana Sports Car Orphanage Gutted upper Intake Manifold plenum with emissions delete
Ported & Polished lower intake manifold
Ported & Polished cylinder heads
Schnider Racing Cams
Precision 880cc fuel injectors
bullit aluminum fuel rails
Walbro 255 in tank fuel pump
Aeromotive fuel pressure regulator
Front mount engine oil cooler
Polyurethane Engine mountsExhaust
Ported stock exhaust manifolds
Ported stock turbo turbine housing (T3)
Ported internal wastegate
Ported turbo exhaust outlet elbow
Certified Muffler 3 inch exhaust (cat delete with Magnaflow muffler)Drive train:
South Bend DXD stage 6 clutch
Fidanza Aluminum Flywheel
Nissan 30a 5-speed trans
Custom heavy duty 3in diameter steel drive shaft
Welded 3:54 rear differential
solid differential mount
88 turbo subframe poly mountedChassis & Electrical:
Flexolite dual electric fans
Maxima 90 amp alternator mod
H4 Headlight conversion 100/130 watt bulbs
Autometer boost gauge
Innovate motor sports LM1 wide band
Nistune engine tuning software
MBC 2 stage boost controller (Boost Valve.com)
ZR racing front coil springs (300lb/in)
ZR racing rear coil springs (325lb/in)
Axis Metal Master Brake pads
Goodridge stainless steel brake lines
Z Racing 6 spoke chrome aluminum rims
Front tires.... 225/50/16
Rear tires....Nitto DR's 245/50/16My track times at Interstate dragways, Sabin MN Sunday August 8:
My two best runs on 10lbs boost was
[email protected].... 2.02 60ft
[email protected].... 1.99 60ftMy 4 best runs on 12-13lbs boost was
[email protected] 60ft
[email protected] 60ftMy best run at 15lbs boost was
[email protected] 60ft12-13 lbs boost
http://www.youtube.com/watch?v=JF76ETa951Y
http://www.youtube.com/watch?v=DCWa6BlQKQ015 lbs boost
http://www.youtube.com/watch?v=B0f4jqPBE20Race weight was 3500lbs 58mm turbo, drag radials on E85.
Ported and polished heads with 270H cams 3in exhaust. -
Cura86;269089 wrote:
The mods for the winter...have you done all that? If so I HAVE to come over and check that out!Mods this winter:
Installed~ Nistune engine management
Installed~ 560cc DSM fuel injectors
Half done~ gutted intake plenum" or "Engloid style" (upper intake plenum)
Done~ Replace 7.8:i pistons with 9:1 pistons
Done~ Port the cylinder heads
Done~ Port the Lower intake plenum
Installed~ Certified Muffler 3inch Mandrel bent exhaust
On the shelf~ Front mount intercooler with 2 1/2 inch piping
On the shelf~ HKS Blow off valve
Installed~ Flex-a-lite dual electric cooling fans
On the shelf~polyurethane sub frame mounts in rear sub frame
On the shelf~ Rear camber Mod
On the shelf~ Turbo CV shafts and stub axles (stronger than N/A)
On the shelf~ ZR racing front coil springs (325lb/in)
On the shelf~ Front mount intercooler with 2 1/2 pipingLoteck 3 gauge pod
Autometer temp gage
Autometer oil pressure gauge
Aeromotive Fuel pressure regulator
H4 headlight harness with relays:icon_bigsmurf:
