  4. Z31 Introduction
Z31 Introduction
107 Posts 22 Posters 15.4k Views
  • Cura86C Offline
    Cura86C Offline
    Cura86
    The mods for the winter...have you done all that? If so I HAVE to come over and check that out!
    www.RoadsideSalvage.com
    • JN210J Offline
      JN210J Offline
      JN210
      Jason you've been on here how long?...welcome anyway haha.
      *1989 Nissan 300ZX Z31 *
      > DelSlow;262050 wrote:
      > I like the new JN210
      • z31Z Offline
        z31Z Offline
        z31
        Mods this winter:
        Installed~ Nistune engine management
        Installed~ 560cc DSM fuel injectors
        Half done~ gutted intake plenum" or "Engloid style" (upper intake plenum)
        Done~ Replace 7.8:i pistons with 9:1 pistons
        Done~ Port the cylinder heads
        Done~ Port the Lower intake plenum
        Installed~ Certified Muffler 3inch Mandrel bent exhaust
        On the shelf~ Front mount intercooler with 2 1/2 inch piping
        On the shelf~ HKS Blow off valve
        Installed~ Flex-a-lite dual electric cooling fans
        On the shelf~polyurethane sub frame mounts in rear sub frame
        On the shelf~ Rear camber Mod
        On the shelf~ Turbo CV shafts and stub axles (stronger than N/A)
        On the shelf~ ZR racing front coil springs (325lb/in)
        On the shelf~ Front mount intercooler with 2 1/2 piping
        Loteck 3 gauge pod
        Autometer temp gage
        Autometer oil pressure gauge
        Maxima 90 amp alternator mod
        Aeromotive Fuel pressure regulator
        H4 headlight harness with relays
        :icon_bigsmurf:
        • D S ohMD Offline
          D S ohMD Offline
          D S ohM
          Welcome to the site. I believe we've met...haha.
          I wanna go fast!
          • z31Z Offline
            z31Z Offline
            z31
            Well, if you look up in the upper right corner you can see. :icon_bigsmurf: ^^^^
            • z31Z Offline
              z31Z Offline
              z31
              I installed my 3 inch mandrel bent exhaust. Sounds nice. :icon_cheers:
              • z31Z Offline
                z31Z Offline
                z31
                This is the difference between the stock down pipe VS the CM 3 inch in the area that goes under the transmission cross member. :icon_geek:
                • z31Z Offline
                  z31Z Offline
                  z31
                  9:1 Pistons and rods in assembled short block.
                    bout time you get something done
                      So why didn't you stick good rods and pistons in? or are stock pistons forged?
                        $500 forged pistons >>> $500 exhaust
                        • z31Z Offline
                          z31Z Offline
                          z31
                          $575 Exhaust as A mater of fact. :icon_bigsmurf:
                          • z31Z Offline
                            z31Z Offline
                            z31
                            The stock NA internals have been run at 500 WHP by quite a few people.
                              then why does it seem like there is a rotary engine under your hood??
                              • z31Z Offline
                                z31Z Offline
                                z31
                                Explain? :icon_scratch:
                                  it comes out at least once a year to be rebuilt, much like a rotary
                                    it might not be fast and it might not handle that well but it aint a pimp whip if the lights dont flip.
                                    • z31Z Offline
                                      z31Z Offline
                                      z31
                                      What are you talking about? I haven't rebuilt any motors VG30 motors, and the one I'm currently working on is only half done. So does that count as .5 VG30 motors? :icon_scratch:
                                      • fdfreakF Offline
                                        fdfreakF Offline
                                        fdfreak
                                        how is it going Jason? welcome? i dont know im confused. too many people introducing themselves after they have been on here for 2+years. I might just have to introduce myself again just to start a new thread.
                                        anyway, hope to see you out a little more this summer. you and Gary both. Maybe I go to the wrong events.
                                        12.645@118mph 12.6psi
                                          ok so you haven't rebuilt one yet...... you instead just go buy another stock salvage engine
