  4. Z31 Introduction
Z31 Introduction
107 Posts 22 Posters 16.1k Views
  • GrrG
    GrrG
    shits weak sauce, gonna need more than that
    • SlowicaS
      SlowicaS
      Slowica
      welcome, nice 300
      • z31Z
        z31Z
        z31
        Slowica;269044 wrote:
        welcome, nice 300
        Thank you!
        • bubbaB
          bubbaB
          welcome
          • NikkiaN
            NikkiaN
            Nikkia
            I've always like those model Z's Great Ride!
            1987 Chevy Celebrity Beater "Sullyie"
            1994 Toyota Supra Twin Turbo
            1963 Oldsmobile Super 88 "Abigail"
            2006 Toyota 4Runner "Virginia"
            • DelSlowD
              DelSlowD
              Welcome. I am a fan of those older style Nissans.
              • z31Z
                z31Z
                z31
                Thanx guys :icon_bigsmurf:
                • Cura86C
                  Cura86C
                  Cura86
                  The mods for the winter...have you done all that? If so I HAVE to come over and check that out!
                  www.RoadsideSalvage.com
                  • JN210J
                    JN210J
                    JN210
                    Jason you've been on here how long?...welcome anyway haha.
                    *1989 Nissan 300ZX Z31 *
                    DelSlow;262050 wrote:
                    I like the new JN210
                    • z31Z
                      z31Z
                      z31
                      Mods this winter:
                      Installed~ Nistune engine management
                      Installed~ 560cc DSM fuel injectors
                      Half done~ gutted intake plenum" or "Engloid style" (upper intake plenum)
                      Done~ Replace 7.8:i pistons with 9:1 pistons
                      Done~ Port the cylinder heads
                      Done~ Port the Lower intake plenum
                      Installed~ Certified Muffler 3inch Mandrel bent exhaust
                      On the shelf~ Front mount intercooler with 2 1/2 inch piping
                      On the shelf~ HKS Blow off valve
                      Installed~ Flex-a-lite dual electric cooling fans
                      On the shelf~polyurethane sub frame mounts in rear sub frame
                      On the shelf~ Rear camber Mod
                      On the shelf~ Turbo CV shafts and stub axles (stronger than N/A)
                      On the shelf~ ZR racing front coil springs (325lb/in)
                      On the shelf~ Front mount intercooler with 2 1/2 piping
                      Loteck 3 gauge pod
                      Autometer temp gage
                      Autometer oil pressure gauge
                      Maxima 90 amp alternator mod
                      Aeromotive Fuel pressure regulator
                      H4 headlight harness with relays
                      :icon_bigsmurf:
                      • D S ohMD
                        D S ohMD
                        D S ohM
                        Welcome to the site. I believe we've met...haha.
                        I wanna go fast!
                        • z31Z
                          z31Z
                          z31
                          Well, if you look up in the upper right corner you can see. :icon_bigsmurf: ^^^^
                          • z31Z
                            z31Z
                            z31
                            I installed my 3 inch mandrel bent exhaust. Sounds nice. :icon_cheers:
                            • z31Z
                              z31Z
                              z31
                              This is the difference between the stock down pipe VS the CM 3 inch in the area that goes under the transmission cross member. :icon_geek:
                              • z31Z
                                z31Z
                                z31
                                9:1 Pistons and rods in assembled short block.
                                • GrrG
                                  GrrG
                                  bout time you get something done
                                  • zbrownZ
                                    zbrownZ
                                    So why didn't you stick good rods and pistons in? or are stock pistons forged?
                                    • zbrownZ
                                      zbrownZ
                                      $500 forged pistons >>> $500 exhaust
                                      • z31Z
                                        z31Z
                                        z31
                                        $575 Exhaust as A mater of fact. :icon_bigsmurf:
                                        • z31Z
                                          z31Z
                                          z31
                                          The stock NA internals have been run at 500 WHP by quite a few people.
