  4. Winter mods 2009-10
Winter mods 2009-10
98 Posts 39 Posters 8.7k Views
  • K
    K
    WRX: Ipikes, sti pink injectors or 07 wrx injectors, fuel pump, and retune for more powa! If that doesn't cut it, I will be adding some +10hp stickers
    240:Nardi Personal Steering Wheel and all the stuff to make it work, TunerproRT ECU with Nistune tuning softwear and then dyno tunez!
    • T
      T
      Trafik Jamz
      Complete audio/video overhaul (lightweight package this time around), coilovers, rebuilt bottom end, cams, springs, retainers, valves, fuel rails, fuel pump, injectors, secondary injectors, TGV delete...along with the rest of the supporting mods. I'm sure I'll break my car early on in the season though.
      Edit: Forgot to mention: New pea-shooter. PTE-6262 Billet
      701.541.3484
      • dubbsyD
        dubbsyD
        XJHEAD;296351 wrote:
        Will be doing the following;
        Mini-tub to get some 315-60-15 Radial tires to fit.
        mini-tubs allowed in RS?
        Aren't you running a 335-x-15 now?
        My list:
        The hope is to have most of the parts ordered and ready to install once it warms up. Probably won't have the car back in Fargo until all the snow is gone and its rained a couple times. I want to be track ready by mid-may.
        17x9/10.5 FR500 wheels with 275/40/17 and 315/35/17 NT-05s (unless I change my mind again).
        Swap mechanical oil pressure gauge out for electric because its been nothing but problems with leaks.
        Wideband (probably Innovate LC-1/DB guage kit)
        E-85
        Hope I have enough fuel for E85
        Dyno time
        Finish stringing some wires inside and put the interior back together
        Do some more reading on the twEECer R/T.
        Hope the paxton makes it through the season.
        Hopefully:
        Swap 3-bolt Steeda C/C plates for Maximum Motorsports 4-bolt plates (maybe)
        Battery relocate to trunk and move/rewire MSD to old battery location (needs to be rewired either way).
        Maybe:
        Maximum Motorsports lower control arms if I have troubles fitting the 315s
        We'll see how much I actually get done. I'd like to pick up a trailer sometime between now and May too.
        I'm afraid I'll accidentally end up pulling the car half apart for some odd reason and not have it back together until August.
        • GrrG
          GrrG
          finish wiring, fuel system, finish my headers, get the turbo spinnin (oil lines) and then go destroy the rear axle so i can put a 8.8 in and 275 drag radials. Then it should pull the wheels...
          • SPANISH-RICES
            SPANISH-RICES
            Whole new car. 400whp dd is the goal
            • BryceB
              BryceB
              You should add those either way :icon_cheers:
              • DrifterExtremeD
                DrifterExtremeD
                details?
                I'm going for a 250whp DD ef 4 door.
                should be nice.
                • XJHEADX
                  XJHEADX
                  Mini-tub is legal in RS/U
                  I have 325-50-15 now they are 28" tall
                  The 315-60 is a 30" tall tire.
                  • inspector01I
                    inspector01I
                    Speaking of which, I think I need a freshened up one, add that to the things to do over the winter.....
                    • zbrownZ
                      zbrownZ
                      get turbo setup and rearend done... make around 600hp/600tq at the wheels through the auto on 10psi or less..... not have to worry about breaking anything
                      • dubbsyD
                        dubbsyD
                        ahhh.. had I done the math I guess...
                        • bubbaB
                          bubbaB
                          collect parts for the scoob (put on after winter's over)- still need side skirts, rear bumper (waiting till spring), rear spats and wing (don't know what version yet). And save up for a swap next spring...
                          ruckus - (not winter, but soon as the snow melts and it gets warm again) stretch, do a touch up job on the seat, and maybe a rear coilover and exhaust.
                          • ruthless351R
                            ruthless351R
                            ruthless351
                            Finished rebuilding the gt-40 heads i got last summer, picked up a MSD ignition system, and now looking for some 24lb injectors and a calibrated MAF for the stang.
                            • kylushK
                              kylushK
                              kylush
                              exhaust and longtubes hopefully
                              1998 Z28 Camaro
                              • GrrG
                                GrrG
                                dont do it man, headers on that thing suck ass to put in
                                • A
                                  A
                                  aliengotpsi
                                  2003 EVO 8
                                  Get Coil On Plug $300.00-$400
                                  Get Used Kelford 272/280's $300-400
                                  Ti. Springs and Retainers $400.00
                                  Convert to Speed Density on Stock ECU $400.00 W/ Dyno Tuning
                                  Twin Disk Clutch $1000-1500.00
                                  Should be in the 650 range on 40 psi..(E-85)
                                  1991 Eagle Talon
                                  New turbo set up
                                  Coil On plug
                                  Trans that shifts
                                  NOS
                                  Radiator
                                  Should be in the 600-800 hp
                                  Kevin Smith
                                  Straightlinedetailing.com
                                  • zbrownZ
                                    zbrownZ
                                    word...
                                    how about i give you a free set of truck manifolds and you buy a fabbed hot side for cheaper than what those headers are worth
                                    then you would be talking
                                    • kylushK
                                      kylushK
                                      kylush
                                      so I've heard... was kinda allready thinking it might not be worth the trouble...
                                      zbrown;296442 wrote:
                                      word...
                                      That would be sweet.... not sure if I'd have the cash or time to follow through with the whole thing till probably a year from now when i'm done with school, but I spose it's not too early to start getting everything together. I really would like to turbocharge my car eventually anyhow
                                      1998 Z28 Camaro
                                      • InstigatorI
                                        InstigatorI
                                        Instigator
                                        I want to do the new car mod too. Gotta sell the Lex though.
                                        -Eric
                                        Playtime Performance
                                        '91 Honda Accord - DD
                                        '09 Honda Ruckus - Matte Gray
                                        • wesholeW
                                          wesholeW
                                          Hoping to add more fuckin dents to my car and see what else can get hit.
                                          Completely redoing the ICE and some interior work too. New subs, new amp, new H/U, Nav, etc.....
                                          Maybe a wire tuck and poss some minor bolt ons under the hood.
