  4. Winter mods 2009-10
Winter mods 2009-10
98 Posts 39 Posters 8.7k Views
  • dubbsyD
    dubbsyD
    XJHEAD;296351 wrote:
    Will be doing the following;
    Mini-tub to get some 315-60-15 Radial tires to fit.
    mini-tubs allowed in RS?
    Aren't you running a 335-x-15 now?
    My list:
    The hope is to have most of the parts ordered and ready to install once it warms up. Probably won't have the car back in Fargo until all the snow is gone and its rained a couple times. I want to be track ready by mid-may.
    17x9/10.5 FR500 wheels with 275/40/17 and 315/35/17 NT-05s (unless I change my mind again).
    Swap mechanical oil pressure gauge out for electric because its been nothing but problems with leaks.
    Wideband (probably Innovate LC-1/DB guage kit)
    E-85
    Hope I have enough fuel for E85
    Dyno time
    Finish stringing some wires inside and put the interior back together
    Do some more reading on the twEECer R/T.
    Hope the paxton makes it through the season.
    Hopefully:
    Swap 3-bolt Steeda C/C plates for Maximum Motorsports 4-bolt plates (maybe)
    Battery relocate to trunk and move/rewire MSD to old battery location (needs to be rewired either way).
    Maybe:
    Maximum Motorsports lower control arms if I have troubles fitting the 315s
    We'll see how much I actually get done. I'd like to pick up a trailer sometime between now and May too.
    I'm afraid I'll accidentally end up pulling the car half apart for some odd reason and not have it back together until August.
    • GrrG
      GrrG
      finish wiring, fuel system, finish my headers, get the turbo spinnin (oil lines) and then go destroy the rear axle so i can put a 8.8 in and 275 drag radials. Then it should pull the wheels...
      • SPANISH-RICES
        SPANISH-RICES
        Whole new car. 400whp dd is the goal
        • BryceB
          BryceB
          KA-T_240;296366 wrote:
          I will be adding some +10hp stickers
          You should add those either way :icon_cheers:
          • DrifterExtremeD
            DrifterExtremeD
            details?
            I'm going for a 250whp DD ef 4 door.
            should be nice.
            • XJHEADX
              XJHEADX
              Mini-tub is legal in RS/U
              I have 325-50-15 now they are 28" tall
              The 315-60 is a 30" tall tire.
              • inspector01I
                inspector01I
                Speaking of which, I think I need a freshened up one, add that to the things to do over the winter.....
                • zbrownZ
                  zbrownZ
                  get turbo setup and rearend done... make around 600hp/600tq at the wheels through the auto on 10psi or less..... not have to worry about breaking anything
                  • dubbsyD
                    dubbsyD
                    ahhh.. had I done the math I guess...
                    • bubbaB
                      bubbaB
                      collect parts for the scoob (put on after winter's over)- still need side skirts, rear bumper (waiting till spring), rear spats and wing (don't know what version yet). And save up for a swap next spring...
                      ruckus - (not winter, but soon as the snow melts and it gets warm again) stretch, do a touch up job on the seat, and maybe a rear coilover and exhaust.
                      • ruthless351R
                        ruthless351R
                        ruthless351
                        Finished rebuilding the gt-40 heads i got last summer, picked up a MSD ignition system, and now looking for some 24lb injectors and a calibrated MAF for the stang.
                        • kylushK
                          kylushK
                          kylush
                          exhaust and longtubes hopefully
                          1998 Z28 Camaro
                          • GrrG
                            GrrG
                            dont do it man, headers on that thing suck ass to put in
                            • A
                              A
                              aliengotpsi
                              2003 EVO 8
                              Get Coil On Plug $300.00-$400
                              Get Used Kelford 272/280's $300-400
                              Ti. Springs and Retainers $400.00
                              Convert to Speed Density on Stock ECU $400.00 W/ Dyno Tuning
                              Twin Disk Clutch $1000-1500.00
                              Should be in the 650 range on 40 psi..(E-85)
                              1991 Eagle Talon
                              New turbo set up
                              Coil On plug
                              Trans that shifts
                              NOS
                              Radiator
                              Should be in the 600-800 hp
                              Kevin Smith
                              Straightlinedetailing.com
                              • zbrownZ
                                zbrownZ
                                word...
                                how about i give you a free set of truck manifolds and you buy a fabbed hot side for cheaper than what those headers are worth
                                then you would be talking
                                • kylushK
                                  kylushK
                                  kylush
                                  so I've heard... was kinda allready thinking it might not be worth the trouble...
                                  zbrown;296442 wrote:
                                  word...
                                  That would be sweet.... not sure if I'd have the cash or time to follow through with the whole thing till probably a year from now when i'm done with school, but I spose it's not too early to start getting everything together. I really would like to turbocharge my car eventually anyhow
                                  1998 Z28 Camaro
                                  • InstigatorI
                                    InstigatorI
                                    Instigator
                                    I want to do the new car mod too. Gotta sell the Lex though.
                                    -Eric
                                    Playtime Performance
                                    '91 Honda Accord - DD
                                    '09 Honda Ruckus - Matte Gray
                                    • wesholeW
                                      wesholeW
                                      Hoping to add more fuckin dents to my car and see what else can get hit.
                                      Completely redoing the ICE and some interior work too. New subs, new amp, new H/U, Nav, etc.....
                                      Maybe a wire tuck and poss some minor bolt ons under the hood.
                                      • DelSlowD
                                        DelSlowD
                                        I'm redoing my charge piping, turbo intake, and starting to build the Z6 block to replace mine. Going to go with hard oil lines on the new block.
                                        Possibly a t28 upgrade if it all goes right.
                                        • BassplayerB
                                          BassplayerB
                                          Bassplayer
                                          Paint the hood
                                          Adjustable seat rails
                                          Rewire/ Fully tuck bay
                                          NAWWWWSSSSS(direct port)
                                          1995 GMC Sierra
