  2. Introductions
  3. Introductions
  4. New Here
New Here
36 Posts 12 Posters 6.0k Views
  • bonestock_442B
    bonestock_442B
    bonestock_442
    Grr;316351 wrote:
    that was a borg warner s475 1.32 housing 96mm turbine wheel. bit laggy, but awesome up top
    Exactly what i ordered yesterday. Do you think there is any chance to keep the inner fender in with the same approximate turbo mounting location with a 5" dp?
    • GrrG
      GrrG
      i had 4" DP, 5" really isnt needed IMHO. I had to cut under where the turbo is, but ran a full fender and even the AC box as you can see. look around in here and ask whatever you need to
      http://s214.photobucket.com/albums/cc192/Grrh77/87%20Buick%20GN%20turbo%20LS2/
      • bonestock_442B
        bonestock_442B
        bonestock_442
        wow thanks!
        • zbrownZ
          zbrownZ
          Nice swap!!
          what parts and such?
          • 00Ws6TransAm0
            00Ws6TransAm0
            00Ws6TransAm
            Welcome!
            • untitledfolderU
              untitledfolderU
              untitledfolder
              kylush;316352 wrote:
              Nice, got any pics? Havn't seen your car but like your choice in motor haha. I plan on doing like a built 408 or 418 LQ4 for my car hopefully next year.
              I only had this old pic of his car:
              ichibankilla;213613 wrote:
              Missing a limb doesn't automatically make it a bad piece of ass just like a can of soup with a dent in it at the store doesn't automatically make it a bad can of soup.
              2000 Honda Civic CX LS/Vtec
              http://www.clubredline.net
              • ChristianC
                ChristianC
                Christian
                Can't wait to see more progress Cory..
                Playtime Performance
                06 F-150 Lariat
                • bonestock_442B
                  bonestock_442B
                  bonestock_442
                  zbrown;316363 wrote:
                  Nice swap!!
                  Stock internals, 224/230 comp cams 114 lsa with .580 lift, hand ported 317 heads 9.2ish compression, victor jr intake. Looking to install a single s475 turbo and run some korn thru it again. Looking to see just how far i can push the stock internals. Just swapped the 6.0 in mid summer and made some shakedown runs at BIR and one at Sabin.
                  • kylushK
                    kylushK
                    kylush
                    Any idea how much it weighs? What trans and rearend are you running?
                    1998 Z28 Camaro
                    • bonestock_442B
                      bonestock_442B
                      bonestock_442
                      Raceweight is 3820
                      It has a ford 9" with 35 spline axles and a spool, Transmission is a stock 4l80e with a transgo shift kit.
                      • kylushK
                        kylushK
                        kylush
                        Thats sweet! Real nice numbers from a realatively simple setup should be really sweet once you get some boost behind it. Was just looking on ls1 tech at some stock internal lq4 and lq9 builds, man those motors can hold alot more power with stock bottom ends than i thought they could. What converter are you running?
                        1998 Z28 Camaro
                        • bonestock_442B
                          bonestock_442B
                          bonestock_442
                          Yank PY3600 stall. 4.11 gears(not for long).
                          For the record the 10.8 run was with a 125 shot. All motor it runs 12.1@114.
                          • capitljC
                            capitljC
                            capitlj
                            So the truth comes out. Lol welcome.
                            Mitch Hedberg wrote:
                            2004 Impala LS 3.8
                            • bonestock_442B
                              bonestock_442B
                              bonestock_442
                              Progress report
                              • zbrownZ
                                zbrownZ
                                Looks great! That turbo isn't going anywhere
                                What injectors are you going to run with the E85
                                • DelSlowD
                                  DelSlowD
                                  Honda 220's.
                                  • bonestock_442B
                                    bonestock_442B
                                    bonestock_442
                                    80's to start with. Andy said they may push 750ish rw.
                                    • zbrownZ
                                      zbrownZ
                                      What pump(s)?
                                      • bonestock_442B
                                        bonestock_442B
                                        bonestock_442
                                        A1000 with boost a pump if needed. 60psi base press.
                                        • B_radB
                                          B_radB
                                          B_rad
                                          sweet ride, welcome
                                          92 civic4door: daily
                                          91 civic: project
