  2. Introductions
  3. Introductions
  4. New Here
New Here
36 Posts 12 Posters 6.0k Views
  • BookemB
    BookemB
    Bookem
    Nice car, what did you end up running?
    Legacy GT
    Gmc Suburban
    Hallorann: Fargostreet?
    Hallorann: No, I ain't.
    • bonestock_442B
      bonestock_442B
      bonestock_442
      This is where i'm at, LOL.
      • bonestock_442B
        bonestock_442B
        bonestock_442
        Ran a 10.8 @ 124.
        • GrrG
          GrrG
          ah yes, i remember that part well! check out the manual rack i was telling you about
          full 4" exhaust tucks up nice and sounds great with 2 bullets too!
          • bonestock_442B
            bonestock_442B
            bonestock_442
            what size turbo was that again?
            • GrrG
              GrrG
              that was a borg warner s475 1.32 housing 96mm turbine wheel. bit laggy, but awesome up top
              • kylushK
                kylushK
                kylush
                Nice, got any pics? Havn't seen your car but like your choice in motor haha. I plan on doing like a built 408 or 418 LQ4 for my car hopefully next year.
                1998 Z28 Camaro
                • bonestock_442B
                  bonestock_442B
                  bonestock_442
                  Exactly what i ordered yesterday. Do you think there is any chance to keep the inner fender in with the same approximate turbo mounting location with a 5" dp?
                  • GrrG
                    GrrG
                    i had 4" DP, 5" really isnt needed IMHO. I had to cut under where the turbo is, but ran a full fender and even the AC box as you can see. look around in here and ask whatever you need to
                    http://s214.photobucket.com/albums/cc192/Grrh77/87%20Buick%20GN%20turbo%20LS2/
                    • bonestock_442B
                      bonestock_442B
                      bonestock_442
                      wow thanks!
                      • zbrownZ
                        zbrownZ
                        Nice swap!!
                        what parts and such?
                        • 00Ws6TransAm0
                          00Ws6TransAm0
                          00Ws6TransAm
                          Welcome!
                          • untitledfolderU
                            untitledfolderU
                            untitledfolder
                            I only had this old pic of his car:
                            ichibankilla;213613 wrote:
                            Missing a limb doesn't automatically make it a bad piece of ass just like a can of soup with a dent in it at the store doesn't automatically make it a bad can of soup.
                            2000 Honda Civic CX LS/Vtec
                            http://www.clubredline.net
                            • ChristianC
                              ChristianC
                              Christian
                              Can't wait to see more progress Cory..
                              Playtime Performance
                              06 F-150 Lariat
                              • bonestock_442B
                                bonestock_442B
                                bonestock_442
                                zbrown;316363 wrote:
                                Nice swap!!
                                Stock internals, 224/230 comp cams 114 lsa with .580 lift, hand ported 317 heads 9.2ish compression, victor jr intake. Looking to install a single s475 turbo and run some korn thru it again. Looking to see just how far i can push the stock internals. Just swapped the 6.0 in mid summer and made some shakedown runs at BIR and one at Sabin.
                                • kylushK
                                  kylushK
                                  kylush
                                  Any idea how much it weighs? What trans and rearend are you running?
                                  1998 Z28 Camaro
                                  • bonestock_442B
                                    bonestock_442B
                                    bonestock_442
                                    Raceweight is 3820
                                    It has a ford 9" with 35 spline axles and a spool, Transmission is a stock 4l80e with a transgo shift kit.
                                    • kylushK
                                      kylushK
                                      kylush
                                      Thats sweet! Real nice numbers from a realatively simple setup should be really sweet once you get some boost behind it. Was just looking on ls1 tech at some stock internal lq4 and lq9 builds, man those motors can hold alot more power with stock bottom ends than i thought they could. What converter are you running?
                                      1998 Z28 Camaro
                                      • bonestock_442B
                                        bonestock_442B
                                        bonestock_442
                                        Yank PY3600 stall. 4.11 gears(not for long).
                                        For the record the 10.8 run was with a 125 shot. All motor it runs 12.1@114.
                                        • capitljC
                                          capitljC
                                          capitlj
                                          So the truth comes out. Lol welcome.
                                          Mitch Hedberg wrote:
                                          2004 Impala LS 3.8
