  2. Introductions
  3. Introductions
  4. New Here
New Here
36 Posts 12 Posters 6.0k Views
  • bonestock_442B
    bonestock_442B
    bonestock_442
    Yes, that's me.
    • GrrG
      GrrG
      awesome, you need any info LMK ive been there, talked to you at the track
      • BookemB
        BookemB
        Bookem
        Nice car, what did you end up running?
        Legacy GT
        Gmc Suburban
        Hallorann: Fargostreet?
        Hallorann: No, I ain't.
        • bonestock_442B
          bonestock_442B
          bonestock_442
          This is where i'm at, LOL.
          • bonestock_442B
            bonestock_442B
            bonestock_442
            Ran a 10.8 @ 124.
            • GrrG
              GrrG
              ah yes, i remember that part well! check out the manual rack i was telling you about
              full 4" exhaust tucks up nice and sounds great with 2 bullets too!
              • bonestock_442B
                bonestock_442B
                bonestock_442
                what size turbo was that again?
                • GrrG
                  GrrG
                  that was a borg warner s475 1.32 housing 96mm turbine wheel. bit laggy, but awesome up top
                  • kylushK
                    kylushK
                    kylush
                    Nice, got any pics? Havn't seen your car but like your choice in motor haha. I plan on doing like a built 408 or 418 LQ4 for my car hopefully next year.
                    1998 Z28 Camaro
                    • bonestock_442B
                      bonestock_442B
                      bonestock_442
                      Exactly what i ordered yesterday. Do you think there is any chance to keep the inner fender in with the same approximate turbo mounting location with a 5" dp?
                      • GrrG
                        GrrG
                        i had 4" DP, 5" really isnt needed IMHO. I had to cut under where the turbo is, but ran a full fender and even the AC box as you can see. look around in here and ask whatever you need to
                        http://s214.photobucket.com/albums/cc192/Grrh77/87%20Buick%20GN%20turbo%20LS2/
                        • bonestock_442B
                          bonestock_442B
                          bonestock_442
                          wow thanks!
                          • zbrownZ
                            zbrownZ
                            Nice swap!!
                            what parts and such?
                            • 00Ws6TransAm0
                              00Ws6TransAm0
                              00Ws6TransAm
                              Welcome!
                              • untitledfolderU
                                untitledfolderU
                                untitledfolder
                                I only had this old pic of his car:
                                ichibankilla;213613 wrote:
                                Missing a limb doesn't automatically make it a bad piece of ass just like a can of soup with a dent in it at the store doesn't automatically make it a bad can of soup.
                                2000 Honda Civic CX LS/Vtec
                                http://www.clubredline.net
                                • ChristianC
                                  ChristianC
                                  Christian
                                  Can't wait to see more progress Cory..
                                  Playtime Performance
                                  06 F-150 Lariat
                                  • bonestock_442B
                                    bonestock_442B
                                    bonestock_442
                                    zbrown;316363 wrote:
                                    Nice swap!!
                                    Stock internals, 224/230 comp cams 114 lsa with .580 lift, hand ported 317 heads 9.2ish compression, victor jr intake. Looking to install a single s475 turbo and run some korn thru it again. Looking to see just how far i can push the stock internals. Just swapped the 6.0 in mid summer and made some shakedown runs at BIR and one at Sabin.
                                    • kylushK
                                      kylushK
                                      kylush
                                      Any idea how much it weighs? What trans and rearend are you running?
                                      1998 Z28 Camaro
                                      • bonestock_442B
                                        bonestock_442B
                                        bonestock_442
                                        Raceweight is 3820
                                        It has a ford 9" with 35 spline axles and a spool, Transmission is a stock 4l80e with a transgo shift kit.
                                        • kylushK
                                          kylushK
                                          kylush
                                          Thats sweet! Real nice numbers from a realatively simple setup should be really sweet once you get some boost behind it. Was just looking on ls1 tech at some stock internal lq4 and lq9 builds, man those motors can hold alot more power with stock bottom ends than i thought they could. What converter are you running?
                                          1998 Z28 Camaro
