  2. Introductions
  3. Introductions
  4. New Here
New Here
36 Posts 12 Posters 5.8k Views
  • bonestock_442B Offline
    bonestock_442
    This is where i'm at, LOL.
      bonestock_442
      Bookem;316346 wrote:
      Nice car, what did you end up running?
      Ran a 10.8 @ 124.
        ah yes, i remember that part well! check out the manual rack i was telling you about
        full 4" exhaust tucks up nice and sounds great with 2 bullets too!
          bonestock_442
          what size turbo was that again?
            that was a borg warner s475 1.32 housing 96mm turbine wheel. bit laggy, but awesome up top
            • kylushK Offline
              kylushK Offline
              kylush
              Nice, got any pics? Havn't seen your car but like your choice in motor haha. I plan on doing like a built 408 or 418 LQ4 for my car hopefully next year.
              1998 Z28 Camaro
                bonestock_442
                Exactly what i ordered yesterday. Do you think there is any chance to keep the inner fender in with the same approximate turbo mounting location with a 5" dp?
                  i had 4" DP, 5" really isnt needed IMHO. I had to cut under where the turbo is, but ran a full fender and even the AC box as you can see. look around in here and ask whatever you need to
                  http://s214.photobucket.com/albums/cc192/Grrh77/87%20Buick%20GN%20turbo%20LS2/
                    bonestock_442
                    wow thanks!
                      Nice swap!!
                      what parts and such?
                      • 00Ws6TransAm0 Offline
                        00Ws6TransAm
                        Welcome!
                        • untitledfolderU Offline
                          untitledfolder
                          I only had this old pic of his car:
                          > ichibankilla;213613 wrote:
                          2000 Honda Civic CX LS/Vtec
                          http://www.clubredline.net
                          • ChristianC Offline
                            ChristianC Offline
                            Christian
                            Can't wait to see more progress Cory..
                            Playtime Performance
                            06 F-150 Lariat
                              bonestock_442
                              zbrown;316363 wrote:
                              Nice swap!!
                              Stock internals, 224/230 comp cams 114 lsa with .580 lift, hand ported 317 heads 9.2ish compression, victor jr intake. Looking to install a single s475 turbo and run some korn thru it again. Looking to see just how far i can push the stock internals. Just swapped the 6.0 in mid summer and made some shakedown runs at BIR and one at Sabin.
                              • kylushK Offline
                                kylushK Offline
                                kylush
                                Any idea how much it weighs? What trans and rearend are you running?
                                1998 Z28 Camaro
                                  bonestock_442
                                  Raceweight is 3820
                                  It has a ford 9" with 35 spline axles and a spool, Transmission is a stock 4l80e with a transgo shift kit.
                                  • kylushK Offline
                                    kylushK Offline
                                    kylush
                                    Thats sweet! Real nice numbers from a realatively simple setup should be really sweet once you get some boost behind it. Was just looking on ls1 tech at some stock internal lq4 and lq9 builds, man those motors can hold alot more power with stock bottom ends than i thought they could. What converter are you running?
                                    1998 Z28 Camaro
                                      bonestock_442
                                      Yank PY3600 stall. 4.11 gears(not for long).
                                      For the record the 10.8 run was with a 125 shot. All motor it runs 12.1@114.
                                      • capitljC Offline
                                        capitljC Offline
                                        capitlj
                                        So the truth comes out. Lol welcome.
                                        > Mitch Hedberg wrote:
                                        2004 Impala LS 3.8
                                          bonestock_442
                                          Progress report
