  2. Introductions
  3. Introductions
  4. New Here
New Here
36 Posts 12 Posters 6.0k Views
  • GrrG
    GrrG
    awesome, you need any info LMK ive been there, talked to you at the track
    • BookemB
      BookemB
      Bookem
      Nice car, what did you end up running?
      Legacy GT
      Gmc Suburban
      Hallorann: Fargostreet?
      Hallorann: No, I ain't.
      • bonestock_442B
        bonestock_442B
        bonestock_442
        This is where i'm at, LOL.
        • bonestock_442B
          bonestock_442B
          bonestock_442
          Ran a 10.8 @ 124.
          • GrrG
            GrrG
            ah yes, i remember that part well! check out the manual rack i was telling you about
            full 4" exhaust tucks up nice and sounds great with 2 bullets too!
            • bonestock_442B
              bonestock_442B
              bonestock_442
              what size turbo was that again?
              • GrrG
                GrrG
                that was a borg warner s475 1.32 housing 96mm turbine wheel. bit laggy, but awesome up top
                • kylushK
                  kylushK
                  kylush
                  Nice, got any pics? Havn't seen your car but like your choice in motor haha. I plan on doing like a built 408 or 418 LQ4 for my car hopefully next year.
                  1998 Z28 Camaro
                  • bonestock_442B
                    bonestock_442B
                    bonestock_442
                    Exactly what i ordered yesterday. Do you think there is any chance to keep the inner fender in with the same approximate turbo mounting location with a 5" dp?
                    • GrrG
                      GrrG
                      i had 4" DP, 5" really isnt needed IMHO. I had to cut under where the turbo is, but ran a full fender and even the AC box as you can see. look around in here and ask whatever you need to
                      http://s214.photobucket.com/albums/cc192/Grrh77/87%20Buick%20GN%20turbo%20LS2/
                      • bonestock_442B
                        bonestock_442B
                        bonestock_442
                        wow thanks!
                        • zbrownZ
                          zbrownZ
                          Nice swap!!
                          what parts and such?
                          • 00Ws6TransAm0
                            00Ws6TransAm0
                            00Ws6TransAm
                            Welcome!
                            • untitledfolderU
                              untitledfolderU
                              untitledfolder
                              I only had this old pic of his car:
                              ichibankilla;213613 wrote:
                              Missing a limb doesn't automatically make it a bad piece of ass just like a can of soup with a dent in it at the store doesn't automatically make it a bad can of soup.
                              2000 Honda Civic CX LS/Vtec
                              http://www.clubredline.net
                              • ChristianC
                                ChristianC
                                Christian
                                Can't wait to see more progress Cory..
                                Playtime Performance
                                06 F-150 Lariat
                                • bonestock_442B
                                  bonestock_442B
                                  bonestock_442
                                  zbrown;316363 wrote:
                                  Nice swap!!
                                  Stock internals, 224/230 comp cams 114 lsa with .580 lift, hand ported 317 heads 9.2ish compression, victor jr intake. Looking to install a single s475 turbo and run some korn thru it again. Looking to see just how far i can push the stock internals. Just swapped the 6.0 in mid summer and made some shakedown runs at BIR and one at Sabin.
                                  • kylushK
                                    kylushK
                                    kylush
                                    Any idea how much it weighs? What trans and rearend are you running?
                                    1998 Z28 Camaro
                                    • bonestock_442B
                                      bonestock_442B
                                      bonestock_442
                                      Raceweight is 3820
                                      It has a ford 9" with 35 spline axles and a spool, Transmission is a stock 4l80e with a transgo shift kit.
                                      • kylushK
                                        kylushK
                                        kylush
                                        Thats sweet! Real nice numbers from a realatively simple setup should be really sweet once you get some boost behind it. Was just looking on ls1 tech at some stock internal lq4 and lq9 builds, man those motors can hold alot more power with stock bottom ends than i thought they could. What converter are you running?
                                        1998 Z28 Camaro
                                        • bonestock_442B
                                          bonestock_442B
                                          bonestock_442
                                          Yank PY3600 stall. 4.11 gears(not for long).
                                          For the record the 10.8 run was with a 125 shot. All motor it runs 12.1@114.
