  4. twins build
twins build
33 Posts 16 Posters 6.5k Views
  • QuadaQ
    QuadaQ
    Quada
    Wow that looks good, man! Is your whole truck Rhino-lined?
    • funky_monkey58F
      funky_monkey58F
      funky_monkey58
      How well does she start in the cold without the grid stuff?
      • capitljC
        capitljC
        capitlj
        Indeed haven't you seen it? He uses it to pull the 7 to the right side of the state so we can drool over it.
        Mitch Hedberg wrote:
        2004 Impala LS 3.8
        • T
          T
          TomTom
          Nice welds, you've got skills!
          • zbrownZ
            zbrownZ
            thanks guys!
            yes the pickup has about 8 gallons of bedliner on it, lol
            starts fine without the grids, i usually have it plugged in at home though. started in fargo at 0* without problems though. I dont have my timing advance much so that helps as does keeping the stock compression ratio
            and all my stuff is old, cheap, and slow..... truth
            • zbrownZ
              zbrownZ
              Big thanks to Dave H! (again)
              he got me a new turbo my hands in a week! great, just great
              I traded my 64/68/14 for a new 66/73/.91 from dave
              i felt i just needed some more turbine on the primary because drive pressure stayed nice and around 1:1 until i started adding fuel then it made a nice uphill
              with the new turbo I cant imagine it working any better, boost is instant, and it builds and holds 53psi of boost with 54psi of drive pressure. Moves out very nicely, and it tows like a N14 now
              I cannot get it to surge no matter what i try, I should of done this much sooner
              here you can see the difference in the 68 and 73 turbine, the 73 looks much easier flowing, with a clip cast or cut into it
              also i had to change the hotpipe up some for a T4 flange, i got an extended flange and man that was slick for making an easy to remove and install brace. I feel it turned out fantastic
              new crossover pipe
              and the finished pics
              easier than stock to get to the oil filter
              happy dodge
              and a little bit of rice, haha
              • JoelJ
                JoelJ
                That's sweet man
                • DaveHD
                  DaveHD
                  Very cool! Do you have any dyno sheets from the old setup? It would be cool to dyno it now and compare. 😄
                  • zbrownZ
                    zbrownZ
                    yeah never any dyno beforeit is alot hotter now with the bigger pump though so it really isnt fairbut i do know that if i had done just the twins and nothing else it would of brought about an extra 300ftlbs in WAY sooner
                    • zbrownZ
                      zbrownZ
                      and here is a vid
                      http://www.youtube.com/watch?v=xJkFczQgz7o
                      • GrrG
                        GrrG
                        holy balls, ear orgasm. i need to see this thing in fargo again soon
                        • BassplayerB
                          BassplayerB
                          Bassplayer
                          Daaamn. Do want turbo diesel.
                          1995 GMC Sierra
                          • legacy-user-3898L
                            legacy-user-3898L
                            legacy-user-3898
                            That is so sweet. Nice build Zac
                            • Turbo-d16T
                              Turbo-d16T
                              Turbo-d16
                              Nice Build. sounds great in video
                              2011 Honda Civic EX
                              1995 Honda Civic EX
                              • integra_gsr98I
                                integra_gsr98I
                                You need to open a diesel shop over there in oil country and take all of the oil riggers money....
                                • BassplayerB
                                  BassplayerB
                                  Bassplayer
                                  X2 For real. That would be a lucrative place to put a performance shop at the moment.
                                  1995 GMC Sierra
                                  • zbrownZ
                                    zbrownZ
                                    thanks guys!
                                    and yeah, a diesel shop out here would be bank right now
                                    as long as you could make it smoke you would be making $$$$$$$$, lol
                                    • zbrownZ
                                      zbrownZ
                                      so i still had the original balljoints in this thing, and i am not going to rid of it ever so i decided to stick some good stuff in there
                                      yes probably the most boring $700 worth of parts, but they sure are beefy
                                      big enough that i could not install them with my ball joint press
                                      and you can even rebuild these without removing them
                                      very nice quality IMO
                                      • zbrownZ
                                        zbrownZ
                                        Update, I just changed the intake up. The rubber was bothering me
                                        It is a AFE pro dry filter, 5" plumbing
                                        It whistled loud before, probably too much now
                                        • PSiedTSiP
                                          PSiedTSiP
                                          That's what she said.
                                          spanish-rice;237125 wrote:
