  4. twins build
twins build
33 Posts 16 Posters 6.5k Views
  • zbrownZ
    zbrownZ
    the bottom end got bearings, old looked really good though. (the 12v has the good fully machined forged rods)
    and i added the second turbo drain
    • funky_monkey58F
      funky_monkey58F
      funky_monkey58
      Fucking sweet dude!
      • zbrownZ
        zbrownZ
        funky_monkey58;325541 wrote:
        Fucking sweet dude!
        thanks man
        • zbrownZ
          zbrownZ
          Ok was at a stand still for a good while waiting for my head to get done.
          finally got that, they did a good job, i can nearly see my reflection in the deck surface
          motor is assembled, in, and running...... have one retorque done too
          ill get some vids and pics of everything complete and some analysis of how it feels when i can push it some when the head is good and seated
          I had said that i was going to keep it under 10psi till i got some heat cycles and retorques, but the dang thing comes up to 20psi with hardly any fuel now, such a crazy difference
          with the studs it seems most either have the rocker stands milled down or the valve covers ground to get the valve covers to fit. I took a different approach
          as such
          and the thing already has Luke's links all around on the front end with a box stabilizer so when it was apart i spent the $$ on a Borgeson box and shaft
          thing goes down the road cherry now
          • zbrownZ
            zbrownZ
            Ok first of all the Borgeson steering box is wow, money well spent
            and the response on the twins is CRAZY, and the sounds are crazy, haha
            i havent pushed it past about half throttle but there it comes up to 35psi like a light switch, EGTs never above 1000* yet
            the wastegate on the smaller secondary turbo cracks at around 15psi...... up to around 25psi the primary and secondary are running about 50/50 for boost
            I havent been above that much but above 25psi it moves more to around 2/3 of the boost supported by the primary
            see what it does when the head is seated good... but for now it is killer
            here are some pics
            yes i was one Tbolt clamp short, and i dont have a bend necessary to fab the intake yet
            here is just a shot of the crossover with the bung i put in it
            and i reworked the harness a lot and cleaned that up, ABS crap is gone, grid BS gone, fuel heater BS gone, battery in back, fuel solenoid bs gone
            you can actually change the fuel filter with ease now
            • QuadaQ
              QuadaQ
              Quada
              Wow that looks good, man! Is your whole truck Rhino-lined?
              • funky_monkey58F
                funky_monkey58F
                funky_monkey58
                How well does she start in the cold without the grid stuff?
                • capitljC
                  capitljC
                  capitlj
                  Indeed haven't you seen it? He uses it to pull the 7 to the right side of the state so we can drool over it.
                  Mitch Hedberg wrote:
                  2004 Impala LS 3.8
                  • T
                    T
                    TomTom
                    Nice welds, you've got skills!
                    • zbrownZ
                      zbrownZ
                      thanks guys!
                      yes the pickup has about 8 gallons of bedliner on it, lol
                      starts fine without the grids, i usually have it plugged in at home though. started in fargo at 0* without problems though. I dont have my timing advance much so that helps as does keeping the stock compression ratio
                      and all my stuff is old, cheap, and slow..... truth
                      • zbrownZ
                        zbrownZ
                        Big thanks to Dave H! (again)
                        he got me a new turbo my hands in a week! great, just great
                        I traded my 64/68/14 for a new 66/73/.91 from dave
                        i felt i just needed some more turbine on the primary because drive pressure stayed nice and around 1:1 until i started adding fuel then it made a nice uphill
                        with the new turbo I cant imagine it working any better, boost is instant, and it builds and holds 53psi of boost with 54psi of drive pressure. Moves out very nicely, and it tows like a N14 now
                        I cannot get it to surge no matter what i try, I should of done this much sooner
                        here you can see the difference in the 68 and 73 turbine, the 73 looks much easier flowing, with a clip cast or cut into it
                        also i had to change the hotpipe up some for a T4 flange, i got an extended flange and man that was slick for making an easy to remove and install brace. I feel it turned out fantastic
                        new crossover pipe
                        and the finished pics
                        easier than stock to get to the oil filter
                        happy dodge
                        and a little bit of rice, haha
                        • JoelJ
                          JoelJ
                          That's sweet man
                          • DaveHD
                            DaveHD
                            Very cool! Do you have any dyno sheets from the old setup? It would be cool to dyno it now and compare. 😄
                            • zbrownZ
                              zbrownZ
                              yeah never any dyno beforeit is alot hotter now with the bigger pump though so it really isnt fairbut i do know that if i had done just the twins and nothing else it would of brought about an extra 300ftlbs in WAY sooner
                              • zbrownZ
                                zbrownZ
                                and here is a vid
                                http://www.youtube.com/watch?v=xJkFczQgz7o
                                • GrrG
                                  GrrG
                                  holy balls, ear orgasm. i need to see this thing in fargo again soon
                                  • BassplayerB
                                    BassplayerB
                                    Bassplayer
                                    Daaamn. Do want turbo diesel.
                                    1995 GMC Sierra
                                    • legacy-user-3898L
                                      legacy-user-3898L
                                      legacy-user-3898
                                      That is so sweet. Nice build Zac
                                      • Turbo-d16T
                                        Turbo-d16T
                                        Turbo-d16
                                        Nice Build. sounds great in video
                                        2011 Honda Civic EX
                                        1995 Honda Civic EX
                                        • integra_gsr98I
                                          integra_gsr98I
                                          You need to open a diesel shop over there in oil country and take all of the oil riggers money....
