  4. twins build
twins build
33 Posts 16 Posters 6.5k Views
  • DaveHD
    DaveHD
    Very cool, it will def be interesting to see how they work. 🙂
    • 63vette6
      63vette6
      63vette
      What? I thought you were putting a screw blower on it! 🙂
      • beachbum_jonB
        beachbum_jonB
        beachbum_jon
        Lookin good lookin good. I need to get a tig so I can get started on my compounds for my 3rd gen.
        -John Adams, 1735-1826-
        • zbrownZ
          zbrownZ
          sounds like something up your alley, haha
          • zbrownZ
            zbrownZ
            If you have a cummins, dont be an idiot like me and actually fix the KDP
            i never put the 5 cent piece in and it fell out and took my timing case 😞
            That is why i am doing the twins right now too
            instead of doing all the BS to pull the cam in the pickup to change the gearcase i just picked up jacob's 215 pump motor
            figured i'd build a fresh one with some parts to keep it together
            funny thing is when i pulled my original motor (260k) i pulled a rod cap and there is zero copper showing..... crazy
            so just some stuff i am doing to that
            here is the KDP tab installed on this engine...... and I TIGd the cam gear on so it cant walk off. (it had already moved off some)
            here is the deck cleaned up and prepped, and the block tapped and studs installed
            alot of elbow grease, I didn't use any powertools, i dont want sealing problems
            head is getting worked right now, heavy valve springs/surfacing/valves/guids
            this pic shows the thread engagement difference from the stock headbolts compared to the A1 studs. (lower tape line is deck height)
            these are prefered over the ARPs, they engage the block more and don't require you to mill down the rocker stands
            • zbrownZ
              zbrownZ
              the bottom end got bearings, old looked really good though. (the 12v has the good fully machined forged rods)
              and i added the second turbo drain
              • funky_monkey58F
                funky_monkey58F
                funky_monkey58
                Fucking sweet dude!
                • zbrownZ
                  zbrownZ
                  funky_monkey58;325541 wrote:
                  Fucking sweet dude!
                  thanks man
                  • zbrownZ
                    zbrownZ
                    Ok was at a stand still for a good while waiting for my head to get done.
                    finally got that, they did a good job, i can nearly see my reflection in the deck surface
                    motor is assembled, in, and running...... have one retorque done too
                    ill get some vids and pics of everything complete and some analysis of how it feels when i can push it some when the head is good and seated
                    I had said that i was going to keep it under 10psi till i got some heat cycles and retorques, but the dang thing comes up to 20psi with hardly any fuel now, such a crazy difference
                    with the studs it seems most either have the rocker stands milled down or the valve covers ground to get the valve covers to fit. I took a different approach
                    as such
                    and the thing already has Luke's links all around on the front end with a box stabilizer so when it was apart i spent the $$ on a Borgeson box and shaft
                    thing goes down the road cherry now
                    • zbrownZ
                      zbrownZ
                      Ok first of all the Borgeson steering box is wow, money well spent
                      and the response on the twins is CRAZY, and the sounds are crazy, haha
                      i havent pushed it past about half throttle but there it comes up to 35psi like a light switch, EGTs never above 1000* yet
                      the wastegate on the smaller secondary turbo cracks at around 15psi...... up to around 25psi the primary and secondary are running about 50/50 for boost
                      I havent been above that much but above 25psi it moves more to around 2/3 of the boost supported by the primary
                      see what it does when the head is seated good... but for now it is killer
                      here are some pics
                      yes i was one Tbolt clamp short, and i dont have a bend necessary to fab the intake yet
                      here is just a shot of the crossover with the bung i put in it
                      and i reworked the harness a lot and cleaned that up, ABS crap is gone, grid BS gone, fuel heater BS gone, battery in back, fuel solenoid bs gone
                      you can actually change the fuel filter with ease now
                      • QuadaQ
                        QuadaQ
                        Quada
                        Wow that looks good, man! Is your whole truck Rhino-lined?
                        • funky_monkey58F
                          funky_monkey58F
                          funky_monkey58
                          How well does she start in the cold without the grid stuff?
                          • capitljC
                            capitljC
                            capitlj
                            Indeed haven't you seen it? He uses it to pull the 7 to the right side of the state so we can drool over it.
                            Mitch Hedberg wrote:
                            2004 Impala LS 3.8
                            • T
                              T
                              TomTom
                              Nice welds, you've got skills!
                              • zbrownZ
                                zbrownZ
                                thanks guys!
                                yes the pickup has about 8 gallons of bedliner on it, lol
                                starts fine without the grids, i usually have it plugged in at home though. started in fargo at 0* without problems though. I dont have my timing advance much so that helps as does keeping the stock compression ratio
                                and all my stuff is old, cheap, and slow..... truth
                                • zbrownZ
                                  zbrownZ
                                  Big thanks to Dave H! (again)
                                  he got me a new turbo my hands in a week! great, just great
                                  I traded my 64/68/14 for a new 66/73/.91 from dave
                                  i felt i just needed some more turbine on the primary because drive pressure stayed nice and around 1:1 until i started adding fuel then it made a nice uphill
                                  with the new turbo I cant imagine it working any better, boost is instant, and it builds and holds 53psi of boost with 54psi of drive pressure. Moves out very nicely, and it tows like a N14 now
                                  I cannot get it to surge no matter what i try, I should of done this much sooner
                                  here you can see the difference in the 68 and 73 turbine, the 73 looks much easier flowing, with a clip cast or cut into it
                                  also i had to change the hotpipe up some for a T4 flange, i got an extended flange and man that was slick for making an easy to remove and install brace. I feel it turned out fantastic
                                  new crossover pipe
                                  and the finished pics
                                  easier than stock to get to the oil filter
                                  happy dodge
                                  and a little bit of rice, haha
                                  • JoelJ
                                    JoelJ
                                    That's sweet man
                                    • DaveHD
                                      DaveHD
                                      Very cool! Do you have any dyno sheets from the old setup? It would be cool to dyno it now and compare. 😄
                                      • zbrownZ
                                        zbrownZ
                                        yeah never any dyno beforeit is alot hotter now with the bigger pump though so it really isnt fairbut i do know that if i had done just the twins and nothing else it would of brought about an extra 300ftlbs in WAY sooner
                                        • zbrownZ
                                          zbrownZ
                                          and here is a vid
                                          http://www.youtube.com/watch?v=xJkFczQgz7o
