twins build
Fucking sweet dude!
Ok was at a stand still for a good while waiting for my head to get done.
finally got that, they did a good job, i can nearly see my reflection in the deck surface
motor is assembled, in, and running...... have one retorque done too
ill get some vids and pics of everything complete and some analysis of how it feels when i can push it some when the head is good and seated
I had said that i was going to keep it under 10psi till i got some heat cycles and retorques, but the dang thing comes up to 20psi with hardly any fuel now, such a crazy difference
with the studs it seems most either have the rocker stands milled down or the valve covers ground to get the valve covers to fit. I took a different approach
as such
and the thing already has Luke's links all around on the front end with a box stabilizer so when it was apart i spent the $$ on a Borgeson box and shaft
thing goes down the road cherry now
Ok first of all the Borgeson steering box is wow, money well spent
and the response on the twins is CRAZY, and the sounds are crazy, haha
i havent pushed it past about half throttle but there it comes up to 35psi like a light switch, EGTs never above 1000* yet
the wastegate on the smaller secondary turbo cracks at around 15psi...... up to around 25psi the primary and secondary are running about 50/50 for boost
I havent been above that much but above 25psi it moves more to around 2/3 of the boost supported by the primary
see what it does when the head is seated good... but for now it is killer
here are some pics
yes i was one Tbolt clamp short, and i dont have a bend necessary to fab the intake yet
here is just a shot of the crossover with the bung i put in it
and i reworked the harness a lot and cleaned that up, ABS crap is gone, grid BS gone, fuel heater BS gone, battery in back, fuel solenoid bs gone
you can actually change the fuel filter with ease now
How well does she start in the cold without the grid stuff?
thanks guys!
yes the pickup has about 8 gallons of bedliner on it, lol
starts fine without the grids, i usually have it plugged in at home though. started in fargo at 0* without problems though. I dont have my timing advance much so that helps as does keeping the stock compression ratio
and all my stuff is old, cheap, and slow..... truth
Big thanks to Dave H! (again)
he got me a new turbo my hands in a week! great, just great
I traded my 64/68/14 for a new 66/73/.91 from dave
i felt i just needed some more turbine on the primary because drive pressure stayed nice and around 1:1 until i started adding fuel then it made a nice uphill
with the new turbo I cant imagine it working any better, boost is instant, and it builds and holds 53psi of boost with 54psi of drive pressure. Moves out very nicely, and it tows like a N14 now
I cannot get it to surge no matter what i try, I should of done this much sooner
here you can see the difference in the 68 and 73 turbine, the 73 looks much easier flowing, with a clip cast or cut into it
also i had to change the hotpipe up some for a T4 flange, i got an extended flange and man that was slick for making an easy to remove and install brace. I feel it turned out fantastic
new crossover pipe
and the finished pics
easier than stock to get to the oil filter
happy dodge
and a little bit of rice, haha
DaveH;325979 wrote:
Very cool! Do you have any dyno sheets from the old setup? It would be cool to dyno it now and compare.
yeah never any dyno beforeit is alot hotter now with the bigger pump though so it really isnt fairbut i do know that if i had done just the twins and nothing else it would of brought about an extra 300ftlbs in WAY sooner
and here is a vid
Daaamn. Do want turbo diesel.
That is so sweet. Nice build Zac
You need to open a diesel shop over there in oil country and take all of the oil riggers money....
integra_gsr98;326101 wrote:
You need to open a diesel shop over there in oil country and take all of the oil riggers money....X2 For real. That would be a lucrative place to put a performance shop at the moment.
