  4. Latest Dyno run
Latest Dyno run
32 Posts 17 Posters 1.8k Views
  • XJHEADX Offline
    XJHEADX Offline
    XJHEAD
    probe this;188769 wrote:
    4 valve heads? .
    Not available
    more boost?.
    Running plenty, doesn't like more
    bigger turbo's?.
    Big enough
    NITROUS!!!.
    Thought about it
    Not sure what all you have done, but some things to look at.
    Pretty much everything.
    7.64 @ 187 3400 lbs. on KORN
    TTSBF
    RTCTTFMF PTOSITW
    • capitljC Offline
      capitljC Offline
      capitlj
      VTEC? lol
      There is always more power out there but I've never driven anything with more than 550 so ummm yeah
      > Mitch Hedberg wrote:
      2004 Impala LS 3.8
        I've never been in a car with remotely close to that power must be sweet!
        • XJHEADX Offline
          XJHEADX Offline
          XJHEAD
          Running out of fuel now
          TTSBF
          RTCTTFMF PTOSITW
          • M Offline
            M Offline
            musthavemuzk
            well that sux
            Monty
            14.59 at 94.85 still stock
            www.pbase.com/musthavemuzk
            • DaveHD Offline
              DaveHD Offline
              DaveH
              Fuel problem solved, that thing needs a LOT of fuel.
              DaveH
              '94 Supra- 7.77 @ 176mph
                what was up?
                • M Offline
                  M Offline
                  musthavemuzk
                  alot as in more than the 2jz you, Matt or that GS300 run? or similar?
                  as i remember Matt talking about running 3 fuel pumps to supply enough fuel for his. at least i think he said 3. mayb it was the GS300 that ran 3.
                  Monty
                  • DaveHD Offline
                    DaveHD Offline
                    DaveH
                    Bill runs E85, so he needs about 30% more fuel than if he were using gasoline. He was out of fuel pump. He put on my Weldon and that still wasn't enough. Now he has his pump and my Weldon both running in parallel.
                    DaveH
                      So..... How many GPM of fuel are being pumped?
                      • XJHEADX Offline
                        XJHEADX Offline
                        XJHEAD
                        Dave's is rated at about 200 gallons per hour, mine is rated at about 840 Lbs/hour or 124 glns/hour. With each connected separately they each lost pressure at about the same time. Had to add a new return port on the tank and removed fitting where the old return was installed and hooked Dave's into there. Looks sorta funny with 2 -10's up front..
                        It will be at Straight Line Detailing/Straight Line Specialties later this week for a good cleaning if anyone wants to take a look. NO TOUCHING, it is a ticking time bomb right now:eek:
                        TTSBF
                        RTCTTFMF PTOSITW
                        • M Offline
                          M Offline
                          musthavemuzk
                          i see
                          i knew E85 needed more fuel....did not realize thst much more.
                          Monty
