  4. Z31 Introduction
Z31 Introduction
107 Posts 22 Posters 14.2k Views
  • z31Z Offline
    z31Z Offline
    z31
    My track times at Interstate dragways, Sabin MN Sunday August 8:
    My two best runs on 10lbs boost was
    [email protected].... 2.02 60ft
    [email protected].... 1.99 60ft
    My 4 best runs on 12-13lbs boost was
    [email protected] 60ft
    My best run at 15lbs boost was
    12-13 lbs boost
    http://www.youtube.com/watch?v=JF76ETa951Y
    http://www.youtube.com/watch?v=DCWa6BlQKQ0
    15 lbs boost
    http://www.youtube.com/watch?v=B0f4jqPBE20
    Race weight was 3500lbs 58mm turbo, drag radials on E85.
    Ported and polished heads with 270H cams 3in exhaust.
      What rpm's you shifting at Jason?
      • z31Z Offline
        z31Z Offline
        z31
        weshole;314771 wrote:
        what rpm's you shifting at jason?
        6000 rpm
          Why so low?
          • z31Z Offline
            z31Z Offline
            z31
            weshole;314774 wrote:
            Why so low?
            6200 is where the cam drops off in power.
            • z31Z Offline
              z31Z Offline
              z31
              The car has a basic tune in it, so the tuneup is not ideal. I'm gonna have the car dyno tuned to fine tune the timing and fuel to gain some power in all RPM ranges. Hopefully i can get another 50 horse out of it with timing and fuel adjustments and a little more boost.
                I cant imagine the drop off is that drastic that you wont still pull hard if you rev higher.
                  Agreed. Holding the previous gear a little longer can help you get into your mid range power in the next gear. It may also be beneficial to adjust shift times in every gear.
                  • z31Z Offline
                    z31Z Offline
                    z31
                    Ya, i guess i could try going to 7000 rpm next time im at the track.
                      I think your car is faster than you showed and it sure seemed that you were definitely shifting way too soon.
                      • GrrG Offline
                        GrrG Offline
                        Grr
                        that car drops 100hp from 6200-7000. His tq peak is about 4400, shifting any later than 6200 would be a complete waste of time and slow the car down alot.
                        2006 Trailblazer SS- my DD
                          what RPM does he drop to when it shifts?
                          • GrrG Offline
                            GrrG Offline
                            Grr
                            about 4400, shifting at 6200 is about perfect. It really needs a bigger turbine and more cam, but the turbine and housing is killing a solid 40hp up top
                            • z31Z Offline
                              z31Z Offline
                              z31
                              I have been thinking about this. I took a look at the rpm drop on each shift, and this is what i came up with:
                              gear 1-2....1700 rpm
                              gear 2-3....1100 rpm
                              gear 3-4....800 rpm
                              gear 4-5.... 500 rpm
                              This is a dyno sheet of the same setup in another z31. The only differance is im using e85 at 15 lbs of boost with 9:1 compression pistons and, he is using 93oct at 20 lbs of boost with 7.8:1 compression pistons.
                                Im assuming the Green is the HP and the blue is the TQ. If that's the case, theres a lot more rpms avail.
                                • beachbum_jonB Offline
                                  beachbum_jon
                                  judging by that dyno graph, and given that your car makes the same power at the same rpms, shifting at 6200 is about perfect IMO. Why go past that when your power drops off, when you can shift and be right back in the power again?
                                  -John Adams, 1735-1826-
                                  • z31Z Offline
                                    z31Z Offline
                                    z31
                                    Yes.
                                    • BookemB Offline
                                      BookemB Offline
                                      Bookem
                                      I'm guessing since Jason has higher compression and less boost his power band is lower rpm just a bit more power.
                                      Legacy GT
                                      Gmc Suburban
                                      Hallorann: Fargostreet?
                                      Hallorann: No, I ain't.
                                      • z31Z Offline
                                        z31Z Offline
                                        z31
                                        Im currently installing manual trans number 3
                                        • JN210J Offline
                                          JN210J Offline
                                          JN210
                                          fun? why do they keep breaking?
                                          *1989 Nissan 300ZX Z31 *
                                          > DelSlow;262050 wrote:
                                          > I like the new JN210
